[Nagios-devel] Re: [[email protected]: A typo in cgi.cfg-sample]
Thanks for the note - this will be patched shortly.
On 4 May 2005 at 22:54, Dmitry Sivachenko wrote:
> Sorry for report, but I do not see my message in the list...
> ----- Forwarded message from Dmitry Sivachenko
> From: Dmitry Sivachenko
> To: [email protected]
> Date: Tue, 3 May 2005 14:34:20 +0400
> Subject: A typo in cgi.cfg-sample
> User-Agent: Mutt/1.5.9i
> Hello!
> Please apply the following patch to cgi.cfg-sample to keep it in sync
> with nagios.cfg-sample (nagios-2.0b3):
> Thanks!
> --- cgi.cfg.old Tue May 3 14:31:03 2005
> +++ cgi.cfg Tue May 3 14:31:35 2005
> @@ -62,7 +62,7 @@
> # have to be tweaked a bit, as different versions of the plugin
> # use different command line arguments/syntaxes.
> -#nagios_check_command=/usr/local/libexec/nagios/check_nagios
> /var/spool/nagios/status.log 5 '/usr/local/bin/nagios'
> +#nagios_check_command=/usr/local/libexec/nagios/check_nagios
> /var/spool/nagios/status.dat 5 '/usr/local/bin/nagios'
> ----- End forwarded message -----
Ethan Galstad,
Nagios Developer
Email: [email protected]
