[Nagios-devel] Bug with macros expansion and perfdata command?
Hello all,
I've been recently trying to setup nagiostat with my nagios 2.5
installation. Unfortunately, it turns out that there seems to be a bug
with nagios and macros expansion for the service perfdata command.
None of the macros referenced in the command get expanded. I first
thought it was only a problem with the nagiostat documentation being
out-of-date, and had to replace a few macros: $LASTCHECK$ ->
$SERVICELASTCHECK$, $OUTPUT$ -> $SERVICEOUTPUT$ and $PERFDATA$ ->
$SERVICEPERFDATA$, but that wasn't sufficient and the nagiostat script
was still getting empty stuff.
So, I changed the service perfdata command to the one provided in the
example configuration file for testing purposes :
command_line /usr/bin/printf "%b" "$LASTSERVICECHECK$\t$HOSTNAME$\t
$SERVICEDESC$\t$SERVICESTATE$\t$SERVICEATTEMPT$\t$SERVICESTATETYPE$\t
$SERVICEEXECUTIONTIME$\t$SERVICELATENCY$\t$SERVICEOUTPUT$\t
$SERVICEPERFDATA$\n" >> /var/spool/nagios/service-perfdata.out
and I only get empty lines in the /var/spool/nagios/service-perfdata.out
file, which seems to confirm that nagios isn't properly expanding the
macros like with every other command.
Am I doing something stupid? Is this indeed a bug, and if so is it
known and is there a patch for it?
Thanks in advance,
Maxime
