Erik wrote:
> Hi,
> I found a small bug in base/notifications.c (version 2.x and 3.x):
> /* run the command */
> my_system(processed_command,notification_timeout,&early_timeout,&exectime,NULL,0);
> /* check to see if the notification timed out */
> if(early_timeout==TRUE){
> asprintf(&temp_buffer,"Warning: Contact '%s' host
> notification command '%s' timed out after %d
> seconds\n",cntct->name,processed_command,DEFAULT_NOTIFICATION_TIMEOUT);
> write_to_logs_and_console(temp_buffer,NSLOG_HOST_NOTIFICATION |
> NSLOG_RUNTIME_WARNING,TRUE);
> my_free((void **)&temp_buffer);
> It seems obvious that DEFAULT_NOTIFICATION_TIMEOUT must be replaced with
> notification_timeout; in order to get the correct info in the
> notifications log.
> Regards,
> Erik
Good catch! Patches will be in CVS shortly.
Ethan Galstad,
Nagios Developer
Email: [email protected]
