> Here is a log message from after the restart: nagios:
> Warning: Return code of 127 for check of service 'Root / Free Space'
> on host 'host.network.com ' was out of
> bounds. Make sure the plugin you're trying to run actually exists.
Code 127 is "command not found"
(http://www.tldp.org/LDP/abs/html/exitcodes.html) so there is not much
to do except figuring out why nagios can't find your plugin.
Try to 'su nagios' and then run the command exactly as nagios would
(using the full path and so on)
Also, if you are using an out-of-the-box version of nagios 2.0b4, you
only have a local check of the disk through the check_local_disk command
defined in the sample checkcommands.cfg, using the check_disk plugin. If
you are trying to fetch the space available on a remote host, this host
should have both a check client (NSCA, NRPE or anything similar) and the
plugin. If it's your case maybe the error msg is issued by the remote
host and then passed to your nagios probe.
Thibault GENESSAY
ALIADIS
www.aliadis.fr
Tel. 0870 723 724
Fax 04 72 13 90 40
