Re: [Nagios-devel] Nagios ePN and perl modules
Hash: SHA1
Bah. My patch for check_ntp at least allowed it to run under epn, but the
FindBin module is using my nagios' 'bin' directory, and not the 'libexec'.
Probably because that is where the nagios plugin is. I'm not exactly sure
what's going on, but I'll submit another diff later when I get it fixed
(really, this time).
- -Doug
On Thursday 02 May 2002 11:36, Douglas E. Warner wrote:
> Heh. My bad. I forgot that you use 'patch' with a 'diff'.
> I've attached the diff for check_ntp; but I just attached the entire
> mini_epn.c since I reformated spacing to be more consistent. Other than
> that, my changes where minor.
> -Doug
> On Thursday 02 May 2002 10:56, Douglas E. Warner wrote:
> > This is a carry-over from the nagios-users mailling list for the thread
> > titled 'embedded perl setup'.
> > I've hacked mini_epn.c so it accepts longer command lines and check_ntp
> > so that it will work with mini_epn. Let me know whether you would like
> > patches or if diffs are fine.
> > -Doug
Douglas E. Warner Network Engineer
CTI/PAdotNET http://www.pa.net +1 717 503 9006
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.0.6 (GNU/Linux)
Comment: For info see http://www.gnupg.org
iD8DBQE80XxaJV36su0A0xIRAkhhAKCSLUMgSFKqFqWqbdRoQBMiF5Kd6QCfRaiZ
oZwIJSU5mzfCpJwEK6ljKT0=
=7reV
-----END PGP SIGNATURE-----
