[Nagios-devel] Re: Re: Nagios CGI issue
ok have an answer for you..
your syntax is incorrect. or at least the one in your post is.
below `please find the correct (tested) syntax.
http://...../cgi-bin/status.cgi?host=all&hoststatustypes=15&servicestatus&types=253&noheader=FALSE
also the value for noheader can be either true or false, however the existance of the noheader switch is what turns off the header. and you can put , the following url and it will still not put a header....
http://.........../cgi-bin/status.cgi?host=all&hoststatustypes=15&servicestatus&types=253&noheader
but this will not work...
http://........./cgi-bin/status.cgi?host=all&hoststatustypes=15&servicestatustypes=253&noheader
because 'servicestatustypes' is not a vaild switch to pass to the cgi.
just prior to the post i tested both of the working syntaxs to ensure they worked. so if you dont get the proper output you want, its not the normal CGI so your best bet would be to recompile your CGI
this is true in both netsaint and nagios Latest `versions'.
hope this helps have a nice day..
[email protected] wrote:
> --__--__--
> Message: 2
> Date: Wed, 24 Jul 2002 07:35:14 -0700
> From: "local.coder"
> To: "'[email protected]'"
> Subject: [Nagios-devel] Re: Nagios CGI issue
> Dumb question for the week.
> I am calling this url
> /nagios/cgi-bin/status.cgi?
> host=all&hoststatustypes=15&servicestatustypes=253&noheader=FALSE
> I have tried setting noheader to TRUE or FALSE and the header still shows up.
> has anyone else seen this ? I remember looking into this before so this has
> been this way for awhile and I was hoping that I could use it to remove the
> grey box in the upper left with the display filters infromation.
> Thanks.
> This mail sent through IMP: http://horde.org/imp/
> --__--__--
