Re: [Nagios-devel] Unable to stop executing checks with 3.2.2
On 19 Sep 2010, at 11:51, Stephen Gran wrote:
> On Sat, Sep 18, 2010 at 06:57:54PM +0100, Ton Voon said:
>> The test_events.c passes with this change. However, it would be best
>> if a testcase could be written for the problem this is trying to
>> solve, which fails without the patch and passes with the patch. This
>> will ensure the problem will continue to get visibility in future.
>> If you create that testcase, I'd be more than happy to apply.
> So I've been looking at the various test cases you already have, and
> I'm
> not sure if it's going to be simpler to try to plug it into
> test_events.c
> or create a new one
I don't mind as long as the test is written in a way that can be rerun
to confirm success in TAP output.
More docs at http://wiki.nagios.org/index.php/Nagios ... es#Testing
However, I'm guessing you'll find it easier to add more tests to
test_events.c than to create a whole new test_events2.c.
> , so I'm going to outline my thoughts and ask for a
> recommendation.
> The things that this patch addresses and should be tested are (in
> pseudo
> code):
> if execute_service_checks == 1 and execute_host_checks == 1:
> failed service_check schedules a host_check and executes it
> service_check is rescheduled
> else if execute_service_checks == 0 and execute_host_checks == 1:
> service_check is rescheduled instead of executed
> host_check is scheduled at it's normal interval and executed
> else if execute_service_checks == 1 and execute_host_checks == 0:
> host_check is rescheduled instead of run
> else if execute_service_checks == 0 and execute_host_checks == 0:
> a service_check is rescheduled
> a host_check is rescheduled
> That covers my understanding of how the scheduling should work.
This looks about right though, to be honest, I've never delved deeply
into this logic so I can't verify.
> Any advice on where to put that? I admit at first glance I am
> slightly
> daunted by the prospect of learning your test harness for the logic
> above, but I'm willing to try.
The first thing is: can you get the test_events C code to execute
without failure?
The 2nd is to code your scenarios above. The tricky thing here is that
you have to setup all the appropriate variables, then execute
event_execution_loop(). As you success criteria is based on whether
certain events were executed or not, you could probably work this out
by checking the last_check and next_check for specific host/services
afterwards.
I look forward to see those tests!
Ton
