--========GMX42091218291303642851
Content-Type: text/plain; charset="us-ascii"
In statusmap.c, layout_method is an int and therefore shouldn't be escaped (the compiler put a message since int was passed as parameter where a char* is expected). File escape_string-2.diff, lines 271/273.
The HTML was broken when using apostrophs in the host name and/or the host alias (statusmap.cgi) and having escape_html_tags=0 in cgi.cfg. This is corrected in the patch. (escape_html_tags should only influence the plugin output.)
I've patched cmd.cgi to escape host, service and author names and the comment data. The call of url_encode is replaced by escape_string there. As a side effect, the author's name is displayed correctly now ("Nagios+Admin" before, "Nagios Admin" with the patch).
The file escape_string-3.diff includes Armin's patches (escape_string-2.diff) and my patches described above.
> cgiutils.h is generated from cgiutils.h.in by autoconf and is not in CVS.
Thanks. I've used the configure script to generate the cgiutils.h file after your patch.
Regards
Bernd
Ist Ihr Browser Vista-kompatibel? Jetzt die neuesten
Browser-Versionen downloaden: http://www.gmx.net/de/go/browser
Content-Type: application/octet-stream; name="escape_string-3.diff"
Content-Disposition: attachment; filename="escape_string-3.diff"
SW5kZXg6IGNnaS9hdmFpbC5jCj09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09
PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KUkNTIGZpbGU6IC9jdnNyb290L25hZ2lvcy9u
YWdpb3MvY2dpL2F2YWlsLmMsdgpyZXRyaWV2aW5nIHJldmlzaW9uIDEuNTAKZGlmZiAtVTMgLXIx
LjUwIGF2YWlsLmMKLS0tIGNnaS9hdmFpbC5jCTIzIEp1biAyMDA4IDIwOjQ3OjQyIC0wMDAwCTEu
NTAKKysrIGNnaS9hdmFpbC5jCTkgQXVnIDIwMDggMTM6MzI6MTYgLTAwMDAKQEAgLTUxMCwxMyAr
NTEwLDEzIEBACiAJCQlpZihmdWxsX2xvZ19lbnRyaWVzPT1UUlVFKQogCQkJCXByaW50ZigiPGlu
cHV0IHR5cGU9J2hpZGRlbicgbmFtZT0nZnVsbF9sb2dfZW50cmllcycgdmFsdWU9Jyc+XG4iKTsK
IAkJCWlmKGRpc3BsYXlfdHlwZT09RElTUExBWV9IT1NUR1JPVVBfQVZBSUwpCi0JCQkJcHJpbnRm
KCI8aW5wdXQgdHlwZT0naGlkZGVuJyBuYW1lPSdob3N0Z3JvdXAnIHZhbHVlPSclcyc+XG4iLGhv
c3Rncm91cF9uYW1lKTsKKwkJCQlwcmludGYoIjxpbnB1dCB0eXBlPSdoaWRkZW4nIG5hbWU9J2hv
c3Rncm91cCcgdmFsdWU9JyVzJz5cbiIsZXNjYXBlX3N0cmluZyhob3N0Z3JvdXBfbmFtZSkpOwog
CQkJaWYoZGlzcGxheV90eXBlPT1ESVNQTEFZX0hPU1RfQVZBSUwgfHwgZGlzcGxheV90eXBlPT1E
SVNQTEFZX1NFUlZJQ0VfQVZBSUwpCi0JCQkJcHJpbnRmKCI8aW5wdXQgdHlwZT0naGlkZGVuJyBu
YW1lPSdob3N0JyB2YWx1ZT0nJXMnPlxuIix1cmxfZW5jb2RlKGhvc3RfbmFtZSkpOworCQkJCXBy
aW50ZigiPGlucHV0IHR5cGU9J2hpZGRlbicgbmFtZT0naG9zdCcgdmFsdWU9JyVzJz5cbiIsZXNj
YXBlX3N0cmluZyhob3N0X25hbWUpKTsKIAkJCWlmKGRpc3BsYXlfdHlwZT09RElTUExBWV9TRVJW
SUNFX0FWQUlMKQotCQkJCXByaW50ZigiPGlucHV0IHR5cGU9J2hpZGRlbicgbmFtZT0nc2Vydmlj
ZScgdmFsdWU9JyVzJz5cbiIsc3ZjX2Rlc2NyaXB0aW9uKTsKKwkJCQlwcmludGYoIjxpbnB1dCB0
eXBlPSdoaWRkZW4nIG5hbWU9J3NlcnZpY2UnIHZhbHVlPSclcyc+XG4iLGVzY2FwZV9zdHJpbmco
c3ZjX2Rlc2NyaXB0aW9uKSk7CiAJCQlpZihkaXNwbGF5X3R5cGU9PURJU1BMQVlfU0VSVklDRUdS
T1VQX0FWQUlMKQotCQkJCXByaW50ZigiPGlucHV0IHR5cGU9J2hpZGRlbicgbmFtZT0nc2Vydmlj
ZWdyb3VwJyB2YWx1ZT0nJXMnPlxuIix1cmxfZW5jb2RlKHNlcnZpY2Vncm91cF9uYW1lKSk7CisJ
CQkJcHJpbnRmKCI8aW5wdXQgdHlwZT0naGlkZGVuJyBuYW1lPSdzZXJ2aWNlZ3JvdXAnIHZhbHVl
PSclcyc+XG4iLGVzY2FwZV9zdHJpbmcoc2VydmljZWdyb3VwX25hbWUpKTsKIAogCQkJcHJpbnRm
KCI8aW5wdXQgdHlwZT0naGlkZGVuJyBuYW1lPSdhc3N1bWVpbml0aWFsc3RhdGVzJyB2YWx1ZT0n
JXMnPlxuIiwoYXNzdW1lX2luaXRpYWxfc3RhdGVzPT1UUlVFKT8ieWVzIjoibm8iKTsKIAkJCXBy
aW50ZigiPGlucHV0IHR5cGU9J2hpZGRlbicgbmFtZT0nYXNzdW1lc3RhdGVyZXRlbnRpb24nIHZh
bHVlPSclcyc+XG4iLChhc3N1bWVfc3RhdGVfcmV0ZW50aW9uPT1UUlVFKT8ieWVzIjoibm8iKTsK
QEAgLTY0NSwxMyArNjQ1LDEzIEBACiAJICAgICAgICBwcmludGYoIjxmb3JtIG1ldGhvZD1cImdl
dFwiIGFjdGlvbj1cIiVzXCI+XG4iLEFWQUlMX0NHSSk7CiAJCXByaW50ZigiPGlucHV0IHR5cGU9
J2hpZGRlbicgbmFtZT0nc2hvd19sb2dfZW50cmllcycgdmFsdWU9Jyc+XG4iKTsKIAkJaWYoZGlz
cGxheV90eXBlPT1ESVNQTEFZX0hPU1RHUk9VUF9BVkFJTCkKLQkJCXByaW50ZigiPGlucHV0IHR5
cGU9J2hpZGRlbicgbmFtZT0naG9zdGdyb3VwJyB2YWx1ZT0nJXMnPlxuIixob3N0Z3JvdXBfbmFt
ZSk7CisJCQlwcmludGYoIjxpbnB1dCB0eXBlPSdoaWRkZW4nIG5hbWU9J2hvc3Rncm91cCcgdmFs
...[email truncated]...
