Re: [Nagios-devel] Nagios 3 (CVS 10282006) compile error if EPN is
Joerg Linge schrieb:
> Am Montag, 30. Oktober 2006 18:10 schrieb Hendrik Baecker:
>> Hi,
>> I have applied the last patch to current CVS head... it works so far.
>> Hope this doesn't break anything...
> Hi Hendrik,
> have you compiled with ePN support ?
> The latest CVS Code runs with production config (2000 Services) for 7 houres without problems.
> The new Hostcheck logic works good. The check latency is minimal.
> Jörg
Didn't testing so deep but compiled with ePN. Compile looks good so far.
Off-Topic:
I am going to merge my splitted 6000 config to one single config and
we'll test the new logic.
Think in that moment Ethan will complete the new Docs we all will feel
the new force ;)
Hendrik
