[Nagios-devel] chech_http on a no-standard port
nagios-plugins
plugin/check-http.c
plugin/check-tcp.c
I think.
----- Original Message -----
Date: Tue, 13 Jul 2004 12:28:04 +0200
Subject: [Nagios-devel] chech_http on a no-standard port
To: Nagios Developper
Hi
guys!
Do
you know if is it possible to write in the "Status information" (present in
the Service State Information) the port number where I am performing the
check?
I have the problem only when the "Current Status" is NOT OK, because
the message I read is: "Socket timeout after 10 seconds".
I have same problem with check_tcp
command.
If
it is necessary, I will modify the source files .... but I don't know
which ones !
Regards
Marco
