Re: [Nagios-devel] Hosts and Services
Okay, that makes sense.
What about this idea then... (some sort of flag for "execute this
service test on the standard nagios retest policy for service
failures").
define host {
host_name linux-server
address 10.0.0.1
parents linux-server2
hostgroups web-servers
service ping-linux-servers
check_command_line ping ...
execute_on_failure true
service smtp-linux-servers
check_command_line
execute_on_failure false
define host_service {
contact_group linux-admins
Craig
On Fri, 2005-06-17 at 17:36 -0400, Subhendu Ghosh wrote:
> The model for hosts and services exist separately such that if one of a
> number of services fails on a host, the host check command is used to
> verify if the host is up/down before checking all the other services.
> Similarly if a host is down, parent hosts are checked to see if the path
> to host is down or just the target host. This is also done using the host
> check_command.
> So while it might look redundant from a data model perespective - it
> actually is quite useful.
> -sg
