Re: [Nagios-devel] cgi config file name
This feature should already be available in the 2.x code. I didn't
add it to the 1.x branch, as it was more of a feature enhancement,
rather than a bug request. Although that argument could be made...
On 9 Aug 2004 at 16:23, duverger wrote:
> Hi all,
> For H-A cluster purpose, i need to run 2 nagios on the same host. The
> problem is that config file name for cgis is hard coded.
> So i added support of environment variable for cgi config file name
> setting.
> I hope this could be inserted in nagios dev stream.
> Since i do not work with cvs snapshots, i give you a kind of "diff
> file" to see what as changed (very minor) in source code.
> In order to use it, you have to load apache env module and declare in
> "NAGIOS/etc/apache.conf" :
> SetEnv NAGIOS_CGI_CONFIG_FILE /path/to/cgi/config/filename
> *** CUT diff cgiutils.c v1.2 ***
> 240,250d239
> then by parameter given from locations.h */ get_cgi_config_file_by_env(char *filename) env=getenv("NAGIOS_CGI_CONFIG_FILE") ) filename;
> *** CUT diff locations.h.in v1.2 ***
> 34c34
> get_cgi_config_file_by_env("@sysconfdir@/cgi.cfg")
> > #define DEFAULT_CGI_CONFIG_FILE
> *** CUT HERE ***
> *** CUT diff cgiutils.h.in v1.2 ***
> 389a390
> > char * get_cgi_config_file_by_env(char *);
> *** CUT HERE ***
> Regards,
> stef
Ethan Galstad,
Nagios Developer
Email: [email protected]
