Re: [Nagios-devel] Host display problem
------=_NextPart_000_0887_01C7027E.EA010A20
Content-Type: text/plain;
charset="us-ascii"
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf
> Of Baumgartner, Jeremy J
> Sent: November 7, 2006 14:52
> To: [email protected]
> Subject: [Nagios-devel] Host display problem
> I'm seeing a strange occurrance, and it seems like something
> that may have been added as a feature, but I cannot see any
> explaination anywhere else.
> Configuration:
> We use separate files for each server we monitor. We have 3
> files in particular: ntz00.cfg, ntz00a.cfg, and ntz00b.cfg.
> We have identical services defined in ntz00a.cfg and
> ntz00b.cfg, as they are identical systems. ntz00.cfg has 3
> services which are common to the other two, but they are not
> listed in either ntz00a.cfg or ntz00b.cfg. When we view the
> hosts ntz00a or ntz00b on the web interface, the additional
> services in ntz00.cfg appear.
> This isn't necessarily a bad thing, but we don't want this to
> happen, since the host ntz00 "hops" between ntz00a and ntz00b
> in a high-availability setup.
> I'm wondering if this was something that was added as a
> feature, since the hostnames are so similar
> (ntz00/ntz00a/ntz00b), perhaps there is logic built in to
> recognize that and [a-z] are related in this way.
> In any case, any information on this would be greatly
> appreciated. Thank you.
If your configuration is done correctly then it's certainely a regexp
problem. Make sure you have:
use_regexp_matching=0
use_true_regexp_matching=0
In you main Nagios config file.
Thomas
Content-Type: application/x-pkcs7-signature;
name="smime.p7s"
filename="smime.p7s"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...[email truncated]...
