> Hi list,
> First : After compilation, Nagios gives you a nice screen giving you
> options to pass to the make install command. It seems that it has not
> been updated for three because it lacks the make install-webconf.
> *** Main program, CGIs and HTML files installed ***
> You can continue with installing Nagios as follows (type 'make'
> without any arguments for a list of all possible options):
> make install-init
> - This installs the init script in /etc/init.d
> make install-commandmode
> - This installs and configures permissions on the
> directory for holding the external command file
> make install-config
> - This installs sample config files in /usr/local/nagios/etc
> Second : active_host_enabled in nagios.cfg and in host definitions.
> tac.cgi confirms that fact but in the web interface menu view
> configuration --> view config --> hosts says it is not.
> That's all for the moment
> Olivier Jan
Thanks for the report Olivier - Patches for these will be in CVS shortly.
Ethan Galstad
Nagios Developer
___
Email: [email protected]
Web: www.nagios.org
