--------------070307030907090200020405
Ton,
here when we ACK anything the deamon dies. Sometimes it just stops
checking, when I get it like this i will do a strace and send the logs.
[]s.
Ton Voon wrote:
> On 31 Mar 2006, at 10:06, Vadim Korsak wrote:
>> Nagios 2.1 have stopped some times. Last entry in log till it stops -
>> SERVICE FLAPPING ALERT:
>> grep -B 1 "2.1 starting..." /var/log/nagios/nagios.log
>> [1143723946] SERVICE FLAPPING ALERT: _net-n-liepaja-srv;DISK C: free
>> space;STARTED; Service appears to have started flapping (20.5% change
>> >= 20.0% threshold)
>> [1143790405] Nagios 2.1 starting... (PID=6671)
>> [1143792340] SERVICE FLAPPING ALERT: _net-n-liepaja-srv;DISK C: free
>> space;STARTED; Service appears to have started flapping (21.1% change
>> >= 20.0% threshold)
>> [1143792757] Nagios 2.1 starting... (PID=11656)
>> [1143793487] SERVICE FLAPPING ALERT: _net-n-liepaja-srv;DISK C: free
>> space;STARTED; Service appears to have started flapping (21.6% change
>> >= 20.0% threshold)
>> [1143793561] Nagios 2.1 starting... (PID=24024)
>> [1143794252] SERVICE FLAPPING ALERT: _net-n-liepaja-gw;PING
>> gateway;STARTED; Service appears to have started flapping (24.2%
>> change >= 20.0% threshold)
>> [1143794282] Nagios 2.1 starting... (PID=2723)
>> [1143795613] SERVICE FLAPPING ALERT: _net-n-liepaja-srv;DISK C: free
>> space;STARTED; Service appears to have started flapping (21.3% change
>> >= 20.0% threshold)
>> [1143795722] Nagios 2.1 starting... (PID=27191)
>> Nagios itself starts flapping
> Vadim,
> Which platform are you running on? Which configure options did you
> build with?
> When it happens again, can you send a pstree output (want to see if
> nagios has forked other processes - maybe hanging on an external
> command). For each nagios process, can you run an strace to see what
> bit of the code it is currently hanging on.
> Ton
> http://www.altinity.com
> T: +44 (0)870 787 9243
> F: +44 (0)845 280 1725
> Skype: tonvoon
> This SF.Net email is sponsored by xPML, a groundbreaking scripting
> language
> that extends applications into web and mobile media. Attend the live
> webcast
> and join the prime developer group breaking into this new coding
> territory!
> http://sel.as-us.falkag.net/sel?cmd=lnk ... dat=121642
> Nagios-devel mailing list
> [email protected]
__________________________________________________
*Alessandro Ren*
/*OpServices*/
/*Luciana de Abreu, 471 - Sala 403*/
/*Porto Alegre, RS - CEP 90570-060*/
*(* phone 55(51)3061-3588
*4* fax 55(51)3061-3588
*Q* mobile 55(51)8151-8212
*:* email [email protected]
Content-Type: text/html; charset=ISO-8859-1
Ton,
[]s.
entry in log till it stops - SERVICE FLAPPING ALERT:
...[email truncated]...
