Re: [Nagios-devel] a word against web interfaces
On Thu, 2004-06-17 at 10:26 +0100, Ben Clewett wrote:
> > web configuration is obviously evil.
> Why 'obviously'? Web configuration is ideally suited to alterations:
> - Easy to use.
I beg to differ. I found them to all be a major PITA if I tried to do
anything at all elaborate/complex.
> - Can be used where ftp/telnet access is not possible.
If you're letting web traffic in, why wouldn't you let SSH traffic in?
I, for one, would never let a critical box (like my Nagios servers) have
external incoming web access (and, for that matter, *direct* ssh
access).
> - Does not require a restart to nagios.
What? Of course it does. Slapping some random web interface on it
doesn't change its internal functionality.
> - Does not require in depth training about format/layout.
> - On-screen help ensures a flatter learning curve.
As much as Nagios isn't simple, it's not rocket science, either. And
once you have a few hosts set up, it's quite easy to copy off of
existing entries. If THAT is too rough for the person trying to make
changes/additions, perhaps you should reconsider allowing them to alter
a mission-critical service.
> - Can make use of CGI controls like CHECKBOX and SELECT to ensure less
> chance of error.
Not sure why you're labeling them as "CGI controls" when they're just
basic HTML elements, nonetheless I don't think I've ever run into this
where I felt like if I had a GUI on the front end of the configuration
process it would have been avoided. If I skipped something, it's
because I didn't know the person requesting the addition had intended me
to watch the thing that I skipped. I would have skipped it either way,
and they still would have looked at the Nagios screen and said "Hey,
could you turn on XXX, too?"
> - A good security model using HTML authentication.
More secure than...what? FTP and telnet from the outside? yes. SSH,
no way.
> I cannot see web configuration as 'obviously' evil, and I would be very
> interested to know why you feel this way.
> I believe this is a huge gain for nagios and will ensure greater
> acceptance and far less support requests, as well as a far more
> professional feel to the program. These are my of course my personal
> views only. :)
There are third-party packages that deal with this already, and *I*
appreciate that they're not included by default, else I might have the
PHBs a) forcing me to use them or b) trying to make changes themselves
(*shudder*).
