Re: [Nagios-devel] High latencies problem.
On 2/17/2009 2:14 PM, Alessandro Ren wrote:
> On 2/17/2009 1:50 PM, Gerhard Lausser wrote:
> =20
>> Hi,
>> we could lower the latency of a similar installation with these settin=
gs:
>> sleep_time=3D0.01
>> service_inter_check_delay_method=3D0.1
>> service_interleave_factor=3D2
>> =20
Latency is still high, I cound not noticed any change. Bellow the=20
nagios -s output.
OBJECT CONFIG PROCESSING TIMES (* =3D Potential for precache savings=
=20
with -u option)
Read: 0.473605 sec
Resolve: 0.073667 sec *
Recomb Contactgroups: 0.002955 sec *
Recomb Hostgroups: 0.003250 sec *
Dup Services: 0.046368 sec *
Recomb Servicegroups: 0.001850 sec *
Duplicate: 0.017076 sec *
Inherit: 0.009637 sec *
Recomb Contacts: 0.000001 sec *
Sort: 0.000001 sec *
Register: 0.070498 sec
Free: 0.009762 sec
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
TOTAL: 0.733946 sec * =3D 0.180081 sec (24.54%) estimated=
=20
savings
RETENTION DATA TIMES
Read and Process: 1.328613 sec
TOTAL: 1.328613 sec
Timing information on configuration verification is listed below.
CONFIG VERIFICATION TIMES (* =3D Potential for speedup with -x=20
option)
Object Relationships: 0.106222 sec
Circular Paths: 0.008335 sec *
Misc: 0.009630 sec
TOTAL: 0.124187 sec * =3D 0.008335 sec (6.7%) estimated=20
savings
EVENT SCHEDULING TIMES
Get service info: 0.042879 sec
Get host info info: 0.000218 sec
Get service params: 0.000010 sec
Schedule service times: 0.132626 sec
Schedule service events: 0.507549 sec
Get host params: 0.000003 sec
Schedule host times: 0.001774 sec
Schedule host events: 0.197066 sec
TOTAL: 0.882125 sec
Projected scheduling information for host and service checks
is listed below. This information assumes that you are going
to start running Nagios with your current config files.
HOST SCHEDULING INFORMATION
Total hosts: 427
Total scheduled hosts: 427
Host inter-check delay method: SMART
Average host check interval: 300.00 sec
Host inter-check delay: 0.70 sec
Max host check spread: 30 min
First scheduled check: Tue Feb 17 14:39:59 2009
Last scheduled check: Tue Feb 17 14:44:58 2009
SERVICE SCHEDULING INFORMATION
Total services: 11160
Total scheduled services: 11159
Service inter-check delay method: USER-SUPPLIED VALUE
Inter-check delay: 0.10 sec
Interleave factor method: USER-SUPPLIED VALUE
Service interleave factor: 2
Max service check spread: 30 min
First scheduled check: Tue Feb 17 14:49:17 2009
Last scheduled check: Wed Feb 18 03:00:00 2009
CHECK PROCESSING INFORMATION
Check result reaper interval: 5 sec
Max concurrent service checks: 32384
[]s.
>> =20
> I will try them and let you know.
> Tks a lot.
> I am wondering is theat event loop would not work better if we ha=
d
> some threads doing the high and low priority events?
> []s.
> =20
>> Gerhard
>> =20
>>> -----Urspr=FCngliche Nachricht-----
>>> Von: Alessandro Ren [mailto:[email protected]]
>>> Gesendet: Dienstag, 17. Februar 2009 17:18
>>> An: Nagios Developers List
>>> Betreff: [Nagios-devel] High latencies problem.
>>> Hello,
>>> I have a nagios system running with 427 hosts and 11160
>>> services and since I reached 8000 services, I am having
>>> problems with the latency beeing around 100s and 200s.
>>> use_large_installation
...[email truncated]...
