first: running nagios xi R1.3G on the Centos 5.4 VM
I have installed the vmware sdk for perl
I have an ESXi 4.0 host that I want to monitor
I had trouble adding the vmware plugin. After I initally uploaded it, the Monitoring wizard did not appear. I got around this by unzipping the vmware.zip to /usr/local/nagiosxi/html/includes/configwizards
then the vmware wizard appeared
I took the additional step of uploading the check_esx3.pl plugin separately
I am having trouble adding a VMware host w/ the VMware Monitoring wizard
this is the error output that I get
Error: Service check command 'check_esx3_host' specified in service 'CPU Usage for VMHost' for host 'HQESX01' not defined anywhere!
Error: Service check command 'check_esx3_host' specified in service 'Input / Output for VMHost' for host 'HQESX01' not defined anywhere!
Error: Service check command 'check_esx3_host' specified in service 'Memory for VMHost' for host 'HQESX01' not defined anywhere!
Error: Service check command 'check_esx3_host' specified in service 'Networking for VMHost' for host 'HQESX01' not defined anywhere!
Error: Service check command 'check_esx3_host' specified in service 'Services for VMHost' for host 'HQESX01' not defined anywhere!
Error: Service check command 'check_esx3_host' specified in service 'VM Status for VMHost' for host 'HQESX01' not defined anywhere!
when i run the cmd /usr/local/nagiosxi/html/includes/configwizards/vmware/scripts/getguests.pl -H my_host_name -u user -p password
I get a nice full list of guests on my esx host
Any suggestions? tks in advance
Problem adding VMware host
Re: Problem adding VMware host
There should be a config file (.cfg extension) in the templates/ subdirectory where you unzipped the wizard. This file needs to get imported into Nagios. To do this:
1. Copy the file to:
/usr/local/nagios/etc/import
2. Run the following script:
/usr/local/nagiosxi/scripts/reconfigure_nagios.sh
Ethan Galstad
President
Ethan Galstad
President
Worked great, thanks!
Thank you Bryan for the update, please feel free to contact us again if you have any issues or questions.
