Re: [Nagios-devel] semicolons as comments?
To complicate things. Semicolon comments only work within objects and
not in nagios.cfg, cgi.cfg et all ;)
Just got a big error showing the CGI couldn't read the logfile ".. ;
blabla". But 'nagios -v' gave no error.
Yes Chris, you found a bug or a missing check :)
Geert
On Fri, 2002-04-26 at 01:04, Geert Vanderkelen wrote:
> Hey Chris,
> You mailed me about this problem in Nagat and I didn't look at it this
> way.
> IMHO, ;-comments after a "variable value" in an object is rather useless
> and compromises readability. Although they should be kept intact.
> What I did for Nagat is keeping the layout of the object configuration
> files as much as possible. I just forgot about the semicolon stuff.
> Consider it a feature request :)
> Well it looks natural to me, the commenting I mean.
> Regards,
> Geert
> On Thu, 2002-04-25 at 23:56, Chris Meador wrote:
> > Hello all,
> > What is the official status of using semicolons as comments within block
> > definitions (as per the example template configuration files)? All of
> > the documentation seems to say that hash-comments are the only valid
> > comments... But nagios understands the files with semicolons anyway.
> > # here is an example of a definition block using semicolon comments
> > define host {
> > use generic-host ;Name of host
> > template to use
> > ;questionable comment
> > host_name localhost
> > alias localhost
> > address 127.0.0.1
> > regards
> > Chris
> > Chris Meador
> > dotLogix, Inc.
> > (901) 260-7148
> > (901) 634-3430 cell
> > _______________________________________________
> > Nagios-devel mailing list
> > [email protected]
> > https://lists.sourceforge.net/lists/lis ... gios-devel
> Geert Vanderkelen
> Kemuri.Org
> http://kemuri.org
> [email protected]
Geert Vanderkelen
Kemuri.Org
http://kemuri.org
