RE: [Nagios-devel] Service notification commands not being execut
I've done some more investigation, found where to turn on the debugging
(--enable-debug0 .. 4) when running configure, and added a bunch of extra
debug code myself.
The problem I am having occurs in the file common/objects.c in the function
"is_contact_for_service".
The first thing that function does is check if the variable "svc" is null,
and if it is, then exit returning false (meaning no contacts). The code does
pass this check on my system, svc is not null. However, the function then
runs a for loop:
for(temp_contactgroupsmember=svc->contact_groups;temp_contactgroupsmember!=N
ULL;temp_contactgroupsmember=temp_contactgroupsmember->next){
As you can see, the for loop tests against svc->contact_groups indirectly by
way of temp_contactgroupsmember. This value is null.
The debugging code for svc i have inserted tells me that svc is set to:
svc->host_name: fwma01
svc->description: pop3
svc->service_check_command: check_pop
svc->contact_groups->group_name:
so the values are right.
Reading through the code this seems to suggest my contacts.cfg or hosts.cfg
file is wrong - it is finding the contact ejl (me), but then deciding it is
not a contact for that service.
I've pasted the relevant parts of my configs below.
The strangest part is that if the host itself goes down instead of a service
(including the host being tested here), then it does find me as a contact.
Is anyone else confused yet, because I am?
If anyone has any ideas please give me a shout, as i'd quite like to dump
bigbrother and its cpu utilisation and defunct processes.
Ewan.
Config files below...
My contacts.cfg file consists of:
define contact{
contact_name ejl
alias Ewan
service_notification_period 24x7
host_notification_period 24x7
service_notification_options c,u,w,r
host_notification_options d,u,r
service_notification_commands host-notify-by-email
host_notification_commands host-notify-by-email
email ejl
define contactgroup{
contactgroup_name aix-admins
alias AIX Administrators
members ejl
the hosts.cfg file consists of (amongst others)
host_name fwma01
alias fwma01
address 1.1.1.1
use fwlaix_template
define host {
name fwlaix_template
max_check_attempts 1
checks_enabled 1
process_perf_data 1
notification_interval 180
notifications_enabled 1
register 0
define hostgroup{
hostgroup_name aix-servers
alias AIX Servers
contact_groups aix-admins
members fwma03,fwma01,opal,ruby
Finally, the service.cfg file consists of
host_name fwma03,fwma01
service_description pop3
check_command check_pop
normal_check_interval 3
retry_check_interval 1
check_period 24x7
notification_interval 3
notification_options w,u,c,r
