Re: [Nagios-devel] Simple question, possibly 2nd time posted
Kevin Duffield wrote:
> Thank you both for your help. I'm going to write a Java "server"
> to take connections (avoiding the multiple JVM penalty, with thanks
> to the friendly Swede (takk I believe it is)). This server will
> then write what is needed to the external command file (thanks
> to Jorge for comfirming this plan)
No worries. It would be cool to see what you've got when you're done, if
you're allowed to share it.
It's "tack", btw, so 9/10 for pronounciation and effor. ;)
OP5 AB www.op5.se
