Re: [Nagios-devel] Date in Log File
--------------010701000504060608010700
Content-Type: text/plain; charset=ISO-8859-15; format=flowed
Steve Pribyl wrote:
>> Epoch time is 500000 times easier to parse from programs.
> I am not going to disagree with you there. Is there a way to get both in
> there. I will happily write the patch it there is some agreement.
There is no agreement, since you'd have to support the current format and
whatever new format you concoct, and you need to support them by trial and
error. Since there are (for large installs), several million lines of logdata
to parse when creating fe an availability-report, slowing down logparsing
while at the same time making it more complicated is a bad idea.
> Epoch is hard to read by people.
People can use perl, or naglog.c (attached) to get the date in a sort-of
human-readable format. As soon as you start fiddling with such things
though, you'll find that "human-readable" means different things in
different parts of the world.
OP5 AB www.op5.se
Content-Type: text/x-csrc;
name="naglog.c"
Content-Disposition: inline;
filename="naglog.c"
* naglog.c
* This program was written to display Nagios logs with the timestamp
* translated to human-readable (European, Americans are only barely human)
* format. Don't whine if it doesn't work for you, and don't ask me to add
* support for other date-formats.
* Author: Andreas Ericsson
* Copyright: None. This program is in the public domain.
* Compile as such:
* gcc -O2 -pipe -Wall naglog.c -o naglog
#define _XOPEN_SOURCE
#include
#include
#include
int main(int argc, char **argv)
struct tm tm;
FILE *fp;
char buf[8192], *str, date[20];
int i = 1;
if(argc < 2) fp = stdin;
else {
parse_next:
printf("opening %s\n", argv);
fp = fopen(argv[i++], "r");
if(!fp) {
perror("fopen():");
return -1;
while((fgets(buf, sizeof(buf), fp))) {
memset(&tm, 0, sizeof(struct tm));
str = strptime(buf, "[%s] ", &tm);
strftime(date, sizeof(date), "%Y-%m-%d %T", &tm);
printf("%s: %s", date, str);
fclose(fp);
if(i < argc)
goto parse_next;
return 0;
--------------010701000504060608010700--
