Re: [Nagios-devel] Event broker question
Hi Justin
If I'm not misreading you, you can do that with eventhandlers=20
http://nagios.sourceforge.net/docs/3_0/ ... dlers.html
Cheers
Johannes
Justin Amburn wrote:
> Hi all,
> Has anyone written any custom Event broker modules? Does anyone have a=20
> sample module that can call an external shell command when anything=20
> =91critical=92 happens? Thanks for the help!
> Regards,
> Justin Amburn
> Apps built with the Adobe(R) Flex(R) framework and Flex Builder(TM) are
> powering Web 2.0 with engaging, cross-platform capabilities. Quickly an=
d
> easily build your RIAs with Flex Builder, the Eclipse(TM)based developm=
ent
> software that enables intelligent coding and step-through debugging.
> Download the free 60 day trial. http://p.sf.net/sfu/www-adobe-com
> Nagios-devel mailing list
> [email protected]
> =20
--=20
Johannes Dagemark
CTO / VP Engineering
op5 AB
F=F6rsta L=E5nggatan 19
SE-413 27 Gothenburg
cell: +46 733-70 90 24
fax: +46 31-774 04 32
Email: [email protected]
http://www.op5.com/
