shadih rahman wrote:
> Here is an actual query which is coming as empty. Please advise on
> this. Thanks
> INSERT INTO nagios_hostchecks SET instance_id='1',
> host_object_id='1501', check_type='0', is_raw_check='0',
> current_check_attempt='1', max_check_attempts='3', state='0',
> state_type='1', start_time=FROM_UNIXTIME(1254718978),
> start_time_usec='231137', end_time=FROM_UNIXTIME(0),
> end_time_usec='0', timeout='30', early_timeout='0',
> execution_time='0.000000', latency='0.230000', return_code='0',
> output='', perfdata='(null)', command_object_id='2', command_args='',
> command_line='/usr/lib64/nagios/plugins/check_fping -H
> xxxxx\.net\.xxxxxx -w 3000\.0,100% -c 3000\.0,100% -n 1' ON DUPLICATE
> KEY UPDATE instance_id='1', host_object_id='1501', check_type='0',
> is_raw_check='0', current_check_attempt='1', max_check_attempts='3',
> state='0', state_type='1', start_time=FROM_UNIXTIME(1254718978),
> output='', perfdata='(null)' |
> | 612 | root | localhost | nagios | Query | 0 | NULL | show
> full processlist
yep that's a bug since the code for query building is missing the
long_output field.
if(asprintf(&buf1,"instance_id='%lu', host_object_id='%lu',
check_type='%d', is_raw_check='%d', current_check_attempt='%d',
max_check_attempts='%d', state='%d', state_type='%d', start_time=%s,
start_time_usec='%lu', end_time=%s, end_time_usec='%lu', timeout='%d',
early_timeout='%d', execution_time='%lf', latency='%lf',
return_code='%d', output='%s', perfdata='%s'"
,idi->dbinfo.instance_id
,object_id
,check_type
,is_raw_check
,current_check_attempt
,max_check_attempts
,state
,state_type
,ts[0]
,start_time.tv_usec
,ts[1]
,end_time.tv_usec
,timeout
,early_timeout
,execution_time
,latency
,return_code
,es[2]
,es[3]
)==-1)
buf1=NULL;
Regarding the fact that es[3] points to long_output, but is assigned to
perfdata
es[3]=ndo2db_db_escape_string(idi,idi->buffered_input[NDO_DATA_LONGOUTPUT]);
es[4]=ndo2db_db_escape_string(idi,idi->buffered_input[NDO_DATA_PERFDATA]);
I remember that I fixed that some while ago in IDOUtils since the
long_output patch has had some flaws in it.
Latest CVS Head of NDOUtils also contains the bug...
Hf @ Hendrik
Kind regards,
Michael
