On 3/26/2009 5:09 PM, Hendrik Baecker wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Thanks for the code. I hope I find some time to check it.
> Alessandro Ren schrieb:
> =20
>> The patch needs http://tpl.sourceforge.net, the serialization
>> library, LZO, libmemcache and the memcache daemon.
>> =20
> Sounds for to much dependencies to go upstream... ;(
> =20
>> The good thing about the way it=B4s done is that if it can not g=
et
>> from the memcache or if the memcache crashes, the CGis will work as
>> normal, parsing all the content all the time.
>> =20
> Ok... fault tolerant - nice!
> =20
You will noticed on the code that any error that occurs, with LZO,=20
memcache or even malloc, it just leads to the normal nagios code beeing=20
executed. I did=B4t have any problemas so far with this patch running in=20
several systems.
Any ideias on how to improve it, would be much appreciated.
[]s.
> =20
>> In the code the part that should handle comments are commented ou=
t,
>> because our comments are in database.
>> []s.
>> Alessandro Ren
>> OpServices
>> _______________________________________________
>> Nagios-devel mailing list
>> [email protected]
>> https://lists.sourceforge.net/lists/lis ... gios-devel
>> =20
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> iEYEARECAAYFAknL4OkACgkQlI0PwfxLQjlMcACfVJY01ylBAYEoIV3XTCXQ6uKo
> GFcAnRIowhtCSDNXOWP2QMsFGoE9Z9+r
> =3DsnWQ
> -----END PGP SIGNATURE-----
> [email protected]
> =20
