>> -----Original Message-----
>> From: [email protected]
>> [mailto:[email protected]] On Behalf
>> Of Ethan Galstad
>> Sent: February 26, 2007 12:38
>> To: Nagios Developers List
>> Subject: Re: [Nagios-devel] Service dependencies broken in CVS HEAD?
>> You shouldn't need to apply your patch - I've already implemented
>> similar functionality in the CVS code. If you want same host
>> dependencies, don't use the "dependent_host_name",
>> "dependent_hostgroup", or "dependent_servicegroup" directives.
>> define servicedependency{
>> host h1,h2
>> service_description svc1
>> dependent_service_description svc2,svc3
>> I just posted an update to CVS with some code cleanups, but
>> no change in
>> functionality. Should make it easier to understand the code in
>> duplicate_objects().
> Thanks; I'm glad to see this is finally going in (and as I suggested, by
> simply ommiting the dependent_ hosts). I just tested it and it works
> I'm not sure where (you patch is big) but you definately fixed something. It
> works now with exactly the same config as with yesterday's checkout. I don't
> understand where you do it though, I'll have to look closer...
> Thomas
Hmm, well perhaps the ugly variable names got me mixed up when I was
writing the initial code. I guess changing the vars to better suited
names resulted in a bug fix.
Ethan Galstad,
Nagios Developer
Email: [email protected]
