Re: [Nagios-devel] Small read status data patch
Matthias Flacke wrote:
> Hello Ethan, hello list,
> testing around with multiline plugin output Hendrik and I found that the
> long
> plugin output in extinfo.cgi was cut around 2000 bytes. The reason for that
> restriction is a hardcoded buffer definition in function
> xsddefault_read_status_data:
> char input[2048]="";
> I attached a small patch against xsddefault.c to replace '2048' with
> MAX_PLUGIN_OUTPUT_LENGTH. I would prefer this setting instead of
> MAX_INPUT_BUFFER because otherwise numerous buffer definitions will be
> extended and IMO the plugin output length will be likely the longer part
> in future.
> Kind regards,
> Matthias
> --- xdata/xsddefault.c.old 2007-06-22 23:33:06.000000000 +0200
> +++ xdata/xsddefault.c 2007-06-22 23:43:43.000000000 +0200
> @@ -680,7 +680,7 @@
> char *input=NULL;
> mmapfile *thefile=NULL;
> #else
> - char input[2048]="";
> + char input[MAX_PLUGIN_OUTPUT_LENGTH]="";
> FILE *fp=NULL;
> #endif
> int data_type=XSDDEFAULT_NO_DATA;
I'll make the requested change as you suggested. It looks like this
problem was due to some debugging code that I put in the routines over a
year ago to test for a mmap() bug. The debugging code was never
removed, so mmap() wasn't being used. I just changed the code to use
mmap() by default, which should get rid of the line length limitations.
Hopefully it won't break anything.
Ethan Galstad,
Nagios Developer
Email: [email protected]
