[Nagios-devel] bug: cgi compilation fails with gd library version 1.7.3
statusmap.cgi fails to compile:
gcc -g -O2 -DHAVE_CONFIG_H -DNSCGI statusmap.c getcgi.o cgiutils.o auth.o popen.o ../common/objects.c ../xdata/xodtemplate.c ../common/statusdata.c
../xdata/xsddefault.c -lgd -lz -lm -lpng -ljpeg edata.o ../xdata/xedtemplate.c -o statusmap.cgi
statusmap.c: In function `load_image_from_file':
statusmap.c:2192: warning: assignment makes pointer from integer without a cast
/tmp/ccJptAaG.o: In function `load_image_from_file':
/home/vsanz/nagios-1.0b3/cgi/statusmap.c:2192: undefined reference to `gdImageCreateFromJpeg'
collect2: ld returned 1 exit status
make: *** [statusmap.cgi] Error 1
System: Debian GNU 2.2 Potato.
Documentation says gd library 1.6.3 or higher is required by CGIs, but jpeg support is included only after versions >=1.8
A suggested solution is check the version of the gd library and drop jpeg support when needed. (Sorry, but I don't have the autoconf skills ).
A workaround: comment offending lines in statusmap.c:
/* else if(!strcasecmp(ext,".jpg") || !strcasecmp(ext,".jpeg"))
im=gdImageCreateFromJpeg(fp);
Regards.
