I have a "gruik" patch solution .......
in src/db.c and src/ndomod.c :
#include
#include
#include
#include
#include
#define CHUNKSIZE 512
int
vasprintf(char **ret, const char *fmt, va_list ap)
int chunks;
size_t buflen;
char *buf;
int len;
chunks =3D ((strlen(fmt) + 1) / CHUNKSIZE) + 1;
buflen =3D chunks * CHUNKSIZE;
for (;;) {
if ((buf =3D malloc(buflen)) =3D=3D NULL) {
*ret =3D NULL;
return -1;
len =3D vsnprintf(buf, buflen, fmt, ap);
if (len >=3D 0 && len =3D 0 are required for vsnprintf implementation=20=
that
* return -1 of buffer insufficient
if (len >=3D 0 && len >=3D buflen) {
buflen =3D len + 1;
*ret =3D buf;
return len;
FILE *fp;
*ret =3D NULL;
int
asprintf(char **ret, const char *fmt, ...)
int len;
va_list ap;
va_start(ap, fmt);
len =3D vasprintf(ret, fmt, ap);
va_end(ap);
return len;
Damien
Le 15 avr. 06, =E0 01:35, Damien Basti=E9 a =E9crit :
> Error again ...
> asprintf doesn't exist ? I am trying to find a solution ....
> gcc -g -O2 -DHAVE_CONFIG_H -D BUILD_NAGIOS_2X -o ndo2db-2x ndo2db.c=20=
> dbhandlers-2x.o io.o utils.o db.o -lnsl -lsocket -lmysqlclient -lm
> Undefined first referenced
> symbol in file
> asprintf dbhandlers-2x.o
> ld: fatal: Symbol referencing errors. No output written to ndo2db-2x
> collect2: ld returned 1 exit status
> Damien
> Le 15 avr. 06, =E0 01:33, Damien Basti=E9 a =E9crit :
>> Another error ...
>> ndo2db.c:14:20: mcheck.h: No such file or directory
>> mcheck doesn't exist on Solaris ?
>> I have tried to comment #define DEBUG_MEMORY 1
>> After i have :
>> symbol in file
>> ceil utils.o (symbol belongs to=20
>> implicit dependency /usr/lib/libm.so.2)
>> I have corrected "ceil" problem by adding $(MATHLIBS) in src/Makefile=20=
>> to :
>> ndo2db-2x: ndo2db.c $(NDO_INC) $(NDO_OBJS) $(COMMON_INC)=20
>> $(COMMON_OBJS) dbhandlers-2x.o
>> $(CC) $(CFLAGS) $(DBCFLAGS) -D BUILD_NAGIOS_2X -o ndo2db-2x=20=
>> ndo2db.c dbhandlers-2x.o $(COMMON_OBJS) $(NDO_OBJS) $(LDFLAGS)=20
>> $(DBLDFLAGS) $(LIBS) $(SOCK
>> ETLIBS) $(DBLIBS) $(OTHERLIBS)
>> Damien
>> Le 14 avr. 06, =E0 20:54, Damien Basti=E9 a =E9crit :
>>> Hi,
>>> I have corrected the problem by adding in io.c file :
>>> #define SUN_LEN(ptr) ((size_t) (((struct sockaddr_un *)=20
>>> 0)->sun_path) + strlen ((ptr)->sun_path))
>>> Damien
>>> Le 14 avr. 06, =E0 18:25, Damien Basti=E9 a =E9crit :
>>>> Hi,
>>>> I tried to compil ndoutils with my Solaris 10 box, and i have these=20=
>>>> following errors :
>>>> # make
>>>> cd ./src/; make ; cd ..
>>>> make[1]: Entering directory=20
>>>> `/export/home/compilation/ndoutils-1.3.1/src'
>>>> gcc -g -O2 -DHAVE_CONFIG_H -c -o io.o io.c
>>>> gcc -g -O2 -DHAVE_CONFIG_H -c -o utils.o utils.c
>>>> gcc -g -O2 -DHAVE_CONFIG_H -o file2sock file2sock.c io.o utils.o =20=
>>>> -lm -lnsl -lsocket
>>>> Symbole premi=E8re r=E9f=E9rence
>>>> non d=E9fini dans le fichier
>>>> SUN_LEN io.o
>>>> ld: fatal : Erreurs dans le r=E9f=E9rencement des symboles. Aucun=20=
>>>> r=E9sultat n'a =E9t=E9 =E9crit dans file2sock
>>>> make[1]: *** [file2sock] Error 1
>>>> make[1]: Leaving directory=20
...[email truncated]...
