Re: [Nagios-devel] MSG_NOSIGNAL problem
On 10/05/2012 07:11 AM, Hayakawa Shinya wrote:
> Hi,
> I am trying to build latest nagioscore copied from SVN repository.
> In my Mac OS X, it fail with following message.
> nerd.c: In function ‘broadcast’:
> nerd.c:205: error: ‘MSG_NOSIGNAL’ undeclared (first use in this function)
> It seems to be needed a patch which is similar to followings.
> https://github.com/ros/ros_comm/commit/ ... c6e25f3109
I haven't got time to verify where SO_NOSIGPIPE exists and where it
doesn't, but I've added a patch that resolves the problem.
Thanks for the report :)
OP5 AB www.op5.se
on peace.
