Re: [Nagios-devel] Some errors with SIGSEGV
Hash: SHA1
[email protected] schrieb:
> I compiled nagios on a cleanly system. And I don't use NDOUtils,
> but this SIGSEGV happens nevertheless. What can I do to run nagios.
Hi Matthias,
Do you use more hosts and services than the "localhost.cfg" from a
fresh Nagios install?
If so, try to copy your host and servive definitions, but give them
different names like "localhost2", "localhost3" and so on.
I've got the same situation if my fresh Nagios have to less to do, it
seems.
You can try to hack the gcc optimizer in the Makefile to build the
nagios binary without any optimizing.
Look for the CFLAGS and an -O2 or something similar.
I won't tell you to disable this Flag forever! It might decrease your
nagios performance.
Kind regards
Hendrik
PS. I would suggest to configure your Mail Client to post to this list
not in HTML Format. Each of your lines seems to be only 4 oder 6
pixels high - ugly to read ;)
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.1 (MingW32)
iD8DBQFGAjtMlI0PwfxLQjkRAvNvAJwLNbLsxN2v6+zHRBZ1EE2DZKcWjQCcCeP7
/B5dJ9LPwUolCQvWtRoiEOk=
=c8sD
-----END PGP SIGNATURE-----
