Re: [Nagios-devel] Solaris 10: Running nrpe in a non-global
------_=_NextPart_001_01CA00BF.856BFD22
Content-Type: text/plain;
charset="us-ascii"
Ok, I took out the tcpd wrapper and set tcp_wrappers to false, but same
issue! Here's my inetadm manifest in plaintext:
=20
bash-3.00# inetadm -l svc:/network/nrpe/tcp:default
SCOPE NAME=3DVALUE
name=3D"nrpe"
endpoint_type=3D"stream"
proto=3D"tcp"
isrpc=3DFALSE
wait=3DFALSE
exec=3D"/usr/local/nagios/bin/nrpe -c
/usr/local/nagios/etc/nrpe.cfg -i"
arg0=3D"/usr/local/nagios/bin/nrpe"
user=3D"nagios"
default bind_addr=3D""
default bind_fail_max=3D-1
default bind_fail_interval=3D-1
default max_con_rate=3D-1
default max_copies=3D-1
default con_rate_offline=3D-1
default failrate_cnt=3D40
default failrate_interval=3D60
default inherit_env=3DTRUE
default tcp_trace=3DFALSE
tcp_wrappers=3DFALSE
default connection_backlog=3D10
=20
=20
And here in xml format:
=20
=20
=20
=20
=20
=20
=20
=20
=20
=20
=20
nrpe
=20
=20
=20
=20
Is there something special that needs to go in the SMF def to explicitly
allow SSL?
Thanks!
Justin=20
________________________________
Sent: Wednesday, July 08, 2009 8:01 PM
To: Nagios Developers List
Subject: Re: [Nagios-devel] Solaris 10: Running nrpe in a non-global
zone
=20
Your exec line is wrong. It should read ;
=20
=20
=20
2009/7/9 Justin Amburn
...[email truncated]...
Original poster: rant Byers [mailto:[email protected]]=2
