Re: [Nagios-devel] New Nagios implementation proposal
--00c09f748972f985e60479e8fc14
Content-Type: text/plain; charset=ISO-8859-1
Here is the result of a 100K conf with the random check (sleep random
from 0 to 20s if i'm not wrong) and an Merlindb export in the same
server. I will run with a 150K conf, but I think this shows we can
have far more perf if we bypass reaping and send results direct into
memory.
Jean
On Thu, Dec 3, 2009 at 10:36 AM, nap wrote:
> Thanks for this check, gcc in progress :)
> Jean
> On Thu, Dec 3, 2009 at 9:43 AM, Andreas Ericsson wrote:
>> On 12/02/2009 02:45 PM, nap wrote:
>>> Thanks this is very usefull, I'll look at it :)
>>> I test with a random check 1->10 and it's ok for latency. It just
>>> needs a lot of workers so I'm trying to allow workers to launch
>>> several process at a time and so use less workers (from 200->4) and
>>> from now it's even faster an use less memory (one worker is a fork of
>>> poller, and poller is near 10Mo of resident memory so less Worker,
>>> less memory used). I just test with a 200K random time check, 4
>>> workers, 512 process/worker and it runs fine (load average at 3 and
>>> still some %idle available :) ).
>>> Now I'm trying a 300K configuration (still the same random time check) =
:D
>> Try with the attached plugin. It's supposed to simulate a network under
>> extreme stress (ie, when monitoring is most important) by exiting with
>> a random exit-code.
>>> But remember : Shinken is far more than good performances. Its
>>> architecture is also important and I would like to have your feed back
>>> about it too.
>> I'll look into it when I get a few moments to spare. However, I'm fairly
>> certain Nagios has too much momentum and too many in-core modules for an=
y
>> incompatible competitor to take its place.
>> Andreas Ericsson =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 andreas.ericsson@op=
5.se
>> OP5 AB =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 www.op5.s=
e
>> Tel: +46 8-230225 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0Fax: +46 8-230231
>> Considering the successes of the wars on alcohol, poverty, drugs and
>> terror, I think we should give some serious thought to declaring war
>> on peace.
>> Join us December 9, 2009 for the Red Hat Virtual Experience,
>> a free event focused on virtualization and cloud computing.
>> Attend in-depth sessions from your desk. Your couch. Anywhere.
>> http://p.sf.net/sfu/redhat-sfdev2dev
>> _______________________________________________
>> Nagios-devel mailing list
>> [email protected]
>> https://lists.sourceforge.net/lists/lis ... gios-devel
Content-Type: image/png; name="100K_random_mysql.png"
Content-Disposition: attachment; filename="100K_random_mysql.png"
X-Attachment-Id: f_g2t4llgk0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...[email truncated]...
