This patch makes it easier to troubleshoot why external commands
fail by adding more detailed error codes as well as a cmd_error_strerror
function for easy printing. It adds an extra log entry for each failed
command, including malformed commands, commands stemming from OOM errors
etc, as opposed to only logging the fact that those external commands
did not execute properly.
This should hopefully also make it eas(y/ier) to add even better error reporting
and error handling in the future, if necessary.
Signed-off-by: Anton Lofgren
base/commands.c | 42 ++++++++++++++++++++++++++++++------------
include/common.h | 8 ++++++++
2 files changed, 38 insertions(+), 12 deletions(-)
diff --git a/base/commands.c b/base/commands.c
index 363fc06..c30e40d 100644
--- a/base/commands.c
+++ b/base/commands.c
@@ -132,7 +132,7 @@ int shutdown_command_file_worker(void) {
static int command_input_handler(int sd, int events, void *discard) {
- int ret;
+ int ret, cmd_ret;
char *buf;
unsigned long size;
@@ -150,7 +150,10 @@ static int command_input_handler(int sd, int events, void *discard) {
buf[size] = 0;
log_debug_info(DEBUGL_COMMANDS, 1, "Read raw external command '%s'\n", buf);
- process_external_command1(buf);
+ if ((cmd_ret = process_external_command1(buf)) != CMD_ERROR_OK) {
+ logit(NSLOG_EXTERNAL_COMMAND | NSLOG_RUNTIME_WARNING, TRUE, "External command error: %s\n", cmd_error_strerror(cmd_ret));
return 0;
@@ -364,7 +367,7 @@ int process_external_command1(char *cmd) {
log_debug_info(DEBUGL_FUNCTIONS, 0, "process_external_command1()\n");
if(cmd == NULL)
- return ERROR;
+ return CMD_ERROR_MALFORMED_COMMAND;
/* strip the command of newlines and carriage returns */
strip(cmd);
@@ -373,16 +376,16 @@ int process_external_command1(char *cmd) {
/* get the command entry time */
if((temp_ptr = my_strtok(cmd, "[")) == NULL)
- return ERROR;
if((temp_ptr = my_strtok(NULL, "]")) == NULL)
- return ERROR;
entry_time = (time_t)strtoul(temp_ptr, NULL, 10);
/* get the command identifier */
if((temp_ptr = my_strtok(NULL, ";")) == NULL)
- return ERROR;
if((command_id = (char *)strdup(temp_ptr + 1)) == NULL)
- return ERROR;
+ return CMD_ERROR_INTERNAL_ERROR;
/* get the command arguments */
if((temp_ptr = my_strtok(NULL, "\n")) == NULL)
@@ -391,7 +394,7 @@ int process_external_command1(char *cmd) {
args = (char *)strdup(temp_ptr);
if(args == NULL) {
my_free(command_id);
- return ERROR;
/* decide what type of command this is... */
@@ -853,7 +856,7 @@ int process_external_command1(char *cmd) {
my_free(args);
- return ERROR;
+ return CMD_ERROR_UNKNOWN_COMMAND;
/* update statistics for external commands */
@@ -878,7 +881,8 @@ int process_external_command1(char *cmd) {
#endif
/* process the command */
- if ((external_command_ret = process_external_command2(command_type, entry_time, args)) != OK) {
+ external_command_ret = (process_external_command2(command_type, entry_time, args) == OK) ? CMD_ERROR_OK : CMD_ERROR_FAILURE;
+ if (external_command_ret != CMD_ERROR_OK) {
logit(NSLOG_EXTERNAL_COMMAND | NSLOG_RUNTIME_WARNING, TRUE, "Error: External command failed -> %s;%s\n", command_id, args);
@@ -895,7 +899,21 @@ int process_external_command1(char *cmd) {
return external_command_ret;
+const char *cmd_error_strerror(int code) {
+ switch(code) {
+ case CMD_ERROR_OK:
+ return "No error";
+ case CMD_ERROR_FAILURE:
+ return "Command failed";
+ case CMD_ERROR_INTERNAL_ERROR:
+ return "Internal error";
+ case CMD_ERROR_UNKNOWN_COMMAND:
+ return "Unknown or unsupported command";
+ case CMD_ERROR_MALFORMED_COMMAND:
+ return "Malformed command";
+ return "Unknown error";
/* top-level processor for a single external command */
int process_external_command2(int cmd, time_t entry_time, char *args) {
@@ -1283,7 +1301,7 @@ int process_external_command2(int cmd, time_t entry_time, char *args) {
break;
default
...[email truncated]...
