Michael Streb wrote:
> Hi,
> Out of the mysql docs:
> Values in VARCHAR columns are variable-length strings. The length can be
> specified as a value from 0 to 255 before MySQL 5.0.3, and 0 to 65,535 in
> 5.0.3 and later versions. (The maximum effective length of a VARCHAR in
> MySQL 5.0.3 and later is determined by the maximum row size and the
> character set used. The maximum column length is subject to a row size of
> 65,535 bytes, which is shared among all columns.)
> Regards,
> Michael
> Am 13.09.2007 15:21 Uhr schrieb "Andreas Ericsson" unter :
>>> Hi Ethan,
>>> Hi list,
>>> recently went into problems with the "output" field in the
>>> nagios_servicechecks table so i had a deeper look and it turned out that the
>>> field size is set to "varchar(255)" only, i think this should be increased
>>> to something like "varchar(4096)" to make use of the longer serviceoutput in
>>> nagios3x.
>>> I don`t know right now if 4k is the maximum serviceoutput in 3x.
>> It's not, as it's dynamically allocated. 255 is the maximum size for varchar
>> in databases though. Anything larger than that has to be stored as "TEXT"
>> or "BLOB" objects, which means a fairly serious hit to performance (as all
>> those objects get stored in one or more separate files on disk).
I'll change these to TEXT types, as VARCHAR types are limited to 255
bytes prior to MySQL 5.
Ethan Galstad,
Nagios Developer
Email: [email protected]
