--bcaec52997635c4b2104d8152580
Content-Type: text/plain; charset=ISO-8859-1
On Sat, Mar 16, 2013 at 7:49 PM, Kaushal Shriyan
wrote:
> On Sat, Mar 16, 2013 at 7:42 PM, Daniel Wittenberg [email protected]> wrote:
>> I'm guessing this was just a packaging error as I looked in SVN and it
>> looks like it's correct there. The spec file needs some updating it looks
>> like but as far as versions it looks correct.
>> Dan
> Dan, yes it fails when i try to build rpm binary package from the spec
> file. if i open the spec file i see version as 2.13 instead of 2.14. Please
> suggest further.
> Regards,
> Kaushal
Is this bug fix going to take a while, please comment.
Regards,
Kaushal
Content-Type: text/html; charset=ISO-8859-1
On Sat, Mar 16, 2013 at 7:49 PM, Kaushal=
Shriyan <[email protected]> wrote:
On Sat, Mar 16, 2013 a=
t 7:42 PM, Daniel Wittenberg <daniel.wittenberg.r0ko@st=
atefarm.com> wrote:
I'm guessing this was just a packaging error as I looked in SVN an=
d it looks like it's correct there. =A0The spec file needs some updatin=
g it looks like but as far as versions it looks correct.
Dan
Dan, yes it fai=
ls when i try to build rpm binary package from the spec file. if i open the=
spec file i see version as 2.13 instead of 2.14. Please suggest further.
Regards,Kaushal
Hi,Is this bug fix go=
ing to take a while, please comment.Regards,Kaushal
--bcaec52997635c4b2104d8152580--
