[Nagios-devel] [PATCH] fix uninitialized array usage in
https://bugzilla.novell.com/show_bug.cgi?id=212892
sehandlers.c(561): warning #592: variable "end_time" is used before its value
base/sehandlers.c | 18 ++++++++++++++----
1 file changed, 14 insertions(+), 4 deletions(-)
Index: nagios-2.5/base/sehandlers.c
--- nagios-2.5.orig/base/sehandlers.c
+++ nagios-2.5/base/sehandlers.c
@@ -251,7 +251,9 @@ int run_global_service_event_handler(ser
double exectime=0.0;
int result=0;
struct timeval start_time;
+#ifdef USE_EVENT_BROKER
struct timeval end_time;
+#endif
int macro_options=STRIP_ILLEGAL_MACRO_CHARS|ESCAPE_MACRO_CHARS;
#ifdef DEBUG0
@@ -307,10 +309,10 @@ int run_global_service_event_handler(ser
write_to_logs_and_console(temp_buffer,NSLOG_EVENT_HANDLER | NSLOG_RUNTIME_WARNING,TRUE);
/* get end time */
gettimeofday(&end_time,NULL);
-#ifdef USE_EVENT_BROKER
/* send event data to broker */
broker_event_handler(NEBTYPE_EVENTHANDLER_END,NEBFLAG_NONE,NEBATTR_NONE,GLOBAL_SERVICE_EVENTHANDLER,(void *)svc,svc->current_state,svc->state_type,start_time,end_time,exectime,event_handler_timeout,early_timeout,result,global_service_event_handler,processed_command_line,command_output,NULL);
#endif
@@ -334,7 +336,9 @@ int run_service_event_handler(service *s
int result=0;
+#endif
#ifdef DEBUG0
@@ -386,10 +390,10 @@ int run_service_event_handler(service *s
/* get end time */
broker_event_handler(NEBTYPE_EVENTHANDLER_END,NEBFLAG_NONE,NEBATTR_NONE,SERVICE_EVENTHANDLER,(void *)svc,svc->current_state,svc->state_type,start_time,end_time,exectime,event_handler_timeout,early_timeout,result,svc->event_handler,processed_command_line,command_output,NULL);
#endif
@@ -460,7 +464,9 @@ int run_global_host_event_handler(host *
int result=0;
+#endif
#ifdef DEBUG0
@@ -516,10 +522,10 @@ int run_global_host_event_handler(host *
/* get end time */
broker_event_handler(NEBTYPE_EVENTHANDLER_END,NEBFLAG_NONE,NEBATTR_NONE,GLOBAL_HOST_EVENTHANDLER,(void *)hst,hst->current_state,hst->state_type,start_time,end_time,exectime,event_handler_timeout,early_timeout,result,global_host_event_handler,processed_command_line,command_output,NULL);
#endif
@@ -542,7 +548,9 @@ int run_host_event_handler(host *hst){
int result=0;
+#endif
#ifdef DEBUG0
@@ -558,6 +566,8 @@ int run_host_event_handler(host *hst){
+ end_time.tv_sec=0L;
+ end_time.tv_usec=0L;
broker_event_handler(NEBTYPE_EVENTHANDLER_START,NEBFLAG_NONE,NEBATTR_NONE,HOST_EVENTHANDLER,(void *)hst,hst->current_state,hst->state_type,start_time,end_time,exectime,event_handler_timeout,early_timeout,result,hst->event_handler,NULL,NULL,NULL);
#endif
@@ -592,10 +602,10 @@ int run_host_event_handler(host *hst){
/* get end time */
broker_event_handler(NEBTYPE_EVENTHANDLER_END,NEBFLAG_NONE,NEBATTR_NONE,HOST_EVENTHANDLER,(void *)hst,hst->current_state,hst->state_type,start_time,end_time,exectime,event_handler_timeout,early_timeout,result,hst->
...[email truncated]...
