[email protected] wrote:
> Hi again -
> There seems to me to be a "bug" in nagios v1.x (and possibly in v2.x) -
> We run passive checks of hundreds of hosts in several dmz's
> If for some reason nagios loses contact with a server - network error f.x. - we get a huge amount of CRITICAL-messages from nagios. One for each service defined actually on the host in question.
You should only get 1 notification, namely a "host down".
> It would be a lot better for nagios to - by default - let all services depend upon a successful check of nrpe.
> If checking nrpe is ok - do the rest of the checks
> Otherwise don't - and issue a message indicating nrpe-check failed.
Passive checks don't use NRPE.
Anyways, read the docs for service-dependencies.
OP5 AB www.op5.se
