Re: [Nagios-devel] Mass define servicedependency for NRPE services
Hash: SHA1
On 01/09/09 09:02 PM, Mathieu Gagné wrote:
> Hi,
> The subject has already been discussed on this mailinglist but all
> solutions I found did not satisfied my needs.
> I would like to be able to create a servicedependency for each service
> hosted on a host with NRPE installed against the NRPE service itself.
> Unfortunately, servicedependency does not allow you to massively define
> service dependencies against a single service hosted on the same host as
> the service.
This had been implemented in Nagios 3, all you have to do is taking out
the dependent_host[group]_name directive and the dependency will only
affect services within their respective host.
> Basically, I don't want to have to define a servicedependency for each
> host that has NRPE installed on it and even less for each NRPE based
> service.
> I would like to be able to use this definition:
> define servicedependency {
> ; NRPE service for each hosts referred by services in nrpe-services
> ; The NRPE service has previously been mass-defined on all hosts
> ; with NRPE installed using a host template
> service_description NRPE
> ; Every NRPE based services
> ; Each NRPE based service is added to nrpe-services
> ; using a service template
> dependent_servicegroup_name nrpe-services
> execution_failure_criteria n
> notification_failure_criteria c,u
Just add the host_name or hostgroup_name directive (you can put all
hostgroups for instance, or enable wildcards and use *) and you're set.
> How hard would it be to implement this feature? Is it even possible?
> Would it be the right "way" to do it? Any idea? Thanks!
If you need a patch for Nagos 2.x I have one lying around; just let me
know and I'll send it.
Thomas
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFKnc1a6dZ+Kt5BchYRAq+dAKCQdGlJ4FMTdYwBi0qxxgqI5MnfQQCgowR2
yLkt0rZMwJz1M9X5W+Y64sg=
=g4FF
-----END PGP SIGNATURE-----
