[Nagios-devel] New config data ids with every nagios-restart in NDO
Hi Ethan, hi list,
I am wondering if there is any reason, why ids of every config data =
table (hosts, services, ...) in NDO database are changed with every =
nagios restart.
I looked through the source code and found that you truncate nearly all =
tables on nagios restart. In my opinion it would be more pretty not to =
truncate all the tables and fill them completely new, but to do an =
"INSERT INTO ... ON DUPLICATE KEY UPDATE ..." like it is already =
implemented (but not really used so far, I think).
The lines of code which would complete this solution but are missing yet =
are "drop all meanwhile deleted config data entries from every config =
data table, which are marked as inactive in nagios_objects table" after =
filling/updating all config data tables.
This solution has big advances in my opinion, because ids of all objects =
in NDO would never change and you could use them as foreign keys in any =
(web-)interface based on NDO.
Against this background is there any chance, that this change will be =
regarded in near future?
Best regards,
Florian Hueter
it-novum GmbH
Ein Unternehmen der Mehler AG
=20
Florian H=FCter
Softwareengineer
=20
Edelzeller Stra=DFe 44 =20
36043 Fulda =20
=20
FON: +49 (661) 103-884 (-333)
FAX: +49 (661) 103-17884 (-334)
MAIL: [email protected]
WEB: http://www.itnovum.de
=20
Handelsregister: Amtsgericht Fulda, HRB 1934
Gesch=E4ftsf=FChrer: Michael Kienle
Sitz der Gesellschaft: Fulda, Deutschland/Germany
UstID-Nr: DE813211784
Steuernr.: 018/225/03095
=20
Der Inhalt dieser E-Mail ist vertraulich. Wenn Sie nicht der eigentliche =
Empf=E4nger sein sollten, informieren Sie bitte sofort den Absender oder =
vernichten umgehend diese Mail. Jegliche unerlaubte Vervielf=E4ltigung =
oder Weiterleitung dieser Mail ist strengstens verboten.
=20
This e-mail may contain confidential and/or privileged information. If =
you are not the intended recipient (or have received this e-mail in =
error) please notify the sender immediately and destroy this e-mail. Any =
unauthorised copying, disclosure or distribution of material in this =
e-mail is strictly forbidden.
