Re: [Nagios-devel] readonly user for cgis
This message is in MIME format.
---MOQ1061561978983db5a6d31950be1d75f44b2d03e8b5
Content-Type: text/plain; charset=ISO-8859-1
Here is a tar with the original files I started with, the new files and t=
he=20
diff's.
Ethan, You may want to work this into the current code base.
Using this info.
In cgi.cfg you have two new config options.
authorized_for_commands=3D
authorized_for_comments=3D
So you can now add someone as authroized_for_all_hosts but not add them t=
o the=20
two new options and then they will see all hosts but not comments or the=20
commands pages.
Let me know if you have any problems.
Quoting Dietmar Ruzicka :
> Hi Derrick,
>=20
> I cannot find the diff's in the list. Would you please send them to me.
>=20
> Thanks
>=20
> Dietmar
>=20
>=20
> On Wed, 6 Aug 2003, local.coder wrote:
>=20
> > I have this change.
> >=20
> > I should submit it. really.
> >=20
> > In the config file I have two new options. readonly and
> readonly_for_all_hosts.
> > That's for managers who need to see but not touch.
> >=20
> > Now my version also hides comments from read only users so the noc ca=
n be
> more=20
> > free in what they type there.
> >=20
> > I will send the diff's to the list tommorow when I am back in the off=
ice.
> >=20
> > Derrick
> >=20
>=20
>=20
Content-Type: application/octet-stream; name="read.auth.nagios.tar"
Content-Disposition: attachment; filename="read.auth.nagios.tar"
YXV0aC8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADAwNDA3NTUAMDAwMDAw
MAAwMDAwMDAxADAwMDAwMDAwMDAwADA3NzIxNDIxNjU2ADAwMTIxNzQANQAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAB1c3RhcgAwMHJvb3QAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAb3RoZXIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAwMDAwMDAwADAwMDAw
MDIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABh
dXRoL2F1dGguYwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMDEwMDY0NAAwMDAwMDAw
ADAwMDAwMDEAMDAwMDAwMzM2MjYAMDc3MjE0MjEwMDcAMDAxMzI3NgAwAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHVzdGFyADAwcm9vdAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAABvdGhlcgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADAwMDAwMDAAMDAwMDAw
MgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAC8q
KioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioq
KioqKioqKioqKioqKioqKioqKgogKgogKiBBVVRILkMgLSBBdXRob3JpemF0aW9uIHV0aWxpdGll
cyBmb3IgTmFnaW9zIENHSXMKICoKICogQ29weXJpZ2h0IChjKSAxOTk5LTIwMDIgRXRoYW4gR2Fs
c3RhZCAobmFnaW9zQG5hZ2lvcy5vcmcpCiAqIExhc3QgTW9kaWZpZWQ6ICAgMDQtMjYtMjAwMgog
KgogKiBMaWNlbnNlOgogKgogKiBUaGlzIHByb2dyYW0gaXMgZnJlZSBzb2Z0d2FyZTsgeW91IGNh
biByZWRpc3RyaWJ1dGUgaXQgYW5kL29yIG1vZGlmeQogKiBpdCB1bmRlciB0aGUgdGVybXMgb2Yg
dGhlIEdOVSBHZW5lcmFsIFB1YmxpYyBMaWNlbnNlIGFzIHB1Ymxpc2hlZCBieQogKiB0aGUgRnJl
ZSBTb2Z0d2FyZSBGb3VuZGF0aW9uOyBlaXRoZXIgdmVyc2lvbiAyIG9mIHRoZSBMaWNlbnNlLCBv
cgogKiAoYXQgeW91ciBvcHRpb24pIGFueSBsYXRlciB2ZXJzaW9uLgogKgogKiBUaGlzIHByb2dy
YW0gaXMgZGlzdHJpYnV0ZWQgaW4gdGhlIGhvcGUgdGhhdCBpdCB3aWxsIGJlIHVzZWZ1bCwKICog
YnV0IFdJVEhPVVQgQU5ZIFdBUlJBTlRZOyB3aXRob3V0IGV2ZW4gdGhlIGltcGxpZWQgd2FycmFu
dHkgb2YKICogTUVSQ0hBTlRBQklMSVRZIG9yIEZJVE5FU1MgRk9SIEEgUEFSVElDVUxBUiBQVVJQ
T1NFLiAgU2VlIHRoZQogKiBHTlUgR2VuZXJhbCBQdWJsaWMgTGljZW5zZSBmb3IgbW9yZSBkZXRh
aWxzLgogKgogKiBZb3Ugc2hvdWxkIGhhdmUgcmVjZWl2ZWQgYSBjb3B5IG9mIHRoZSBHTlUgR2Vu
ZXJhbCBQdWJsaWMgTGljZW5zZQogKiBhbG9uZyB3aXRoIHRoaXMgcHJvZ3J
...[email truncated]...
