Thanks for the email.
Symlinks... I confess, I've done the exact same thing before.
Nagios needs two things:
1) graceful handling of empty hostgroups (the bulk of my worries)
and
2) actively monitor hosts based on a nagios instance name
As for the latter (2) each Nagios instance could be named and a
configuration option (host and inheritable to service) named
active_instance would dictate active vs. passive monitoring. Ideally
this variable could be "subscribed" to using hostgroups. Perhaps
someone with a more delicate Nagios vocabulary can understand what I'm
trying to say and translate
Let me demonstrate this fantasy.
define hostgroup{
hostgroup_name MSP_
alias Servers in Minneapolis
instance_name MSP
define hostgroup{
hostgroup_name NYC_
alias Servers in New York
instance_name NYC
define host {
use default
host_name myhost
alias Development WAS
hostgroups NYC_,Linux
use load
hostgroup_name Linux
This simple configuration would only be actively checked by the NYC
nagios host, and be passively checked by the MSP host. Eh?
Caylan
On Jul 14, 2008, at 2:21 PM, Tobias Mucke wrote:
> Hi Caylan,
> what you mentioned, is a common problem in a distributed Nagios
> environment. This can get very complex not only with hostgroups.
> We solved this problem, at least we tried to solve it this way:
> Nearly all configuration objects are found under, except objects which
> have no dependencies on others like commands.
> /etc/nagios/objects/repository
> There you find a directory for every object type.
> /etc/nagios/objects/repository/hosts
> /etc/nagios/objects/repository/services
> /etc/nagios/objects/repository/hostgroups
> For every Nagios host there is a directory beyond
> For example your Nagios hosts are called nms001, dms001 and dms002.
> You have the following directory structure. The first one for the
> central monitoring system is a symbolic link to the repository itself.
> /etc/nagios/objects/nms001 -> /etc/nagios/objects/repository
> /etc/nagios/objects/dms001
> /etc/nagios/objects/dms002
> Beyond the directories for the distributed monitoring systems there is
> a structure like described above.
> /etc/nagios/objects/dms001/hosts
> /etc/nagios/objects/dms001/services
> /etc/nagios/objects/dms001/hostgroups
> Beyond we have symbolic links to the real configuration files, e.g.
> for the host proxy
> /etc/nagios/objects/dms001/hosts/proxy.cfg ->
> /etc/nagios/objects/repository/hosts/proxy.cfg
> If you have such a structure you are able to check configuration
> consistency for each Nagios system before you rsync the configuration
> files to the Nagios systems. Your rsync script can be really simple,
> e.g. with exclude lists, because you are able to sync all and
> reference different directories in Nagios main configuration file.
> We have more than 1000 configuration files here. Maybe you want to
> give this schema a try.
> Anybody else? Any comments appreciated.
> Tobias
> Sponsored by: SourceForge.net Community Choice Awards: VOTE NOW!
> Studies have shown that voting for your favorite open source project,
> along with a healthy diet, reduces your potential for chronic lameness
> and boredom. Vote Now at http://www.sourceforge.net/community/cca08
> Nagios-devel mailing list
> [email protected]
