Re: [Nagios-devel] 3.0.6 status map icon display problems
Christoph Maser
To
Nagios Developers List
01/05/2009 03:04
cc
Please respond to Subject
Nagios Developers Re: [Nagios-devel] 3.0.6 status map
List icon display problems
>James
>i am the one packaging nagios for rpmforge. I do not have this problem
>at all on any installation. Did you properly diff your old config files
>versus the ones the new pacakges provides? Is the output of 'rpmverify
>nagios' clean? Do you use any other 3rd party yum repositories besides
>rpmforge?
>Chris
Chris, bingo. Although I had already done so, I diffed the config files
again to make sure there were no differences. I found the problem in the
cgi.cfg file. The old file had:
physical_html_path=/usr/share/nagios/html
It should have been physical_html_path=/usr/share/nagios
This is fixed and all is working. Thanks!!!
James
