Re: [Nagios-devel] Event Profiler Patch
I made it a compile time option in my patch for ease of insertion in the ex=
isting code base.
It would be trivial to convert it to a config file option.
Just add a new option and track it with a global variable, then search and =
replace all of the #ifdef EVENT_PROFILE tags with a simple if(gEvent_Profil=
e_Enabled)
After that it's just a matter of tracking down the unmatched #endif's and t=
hat should be it.
If there is interest in it, I can update the code to do this and submit a n=
ew patch.
Sincerely,
Steve
________________________________________
Sent: Saturday, June 06, 2009 10:31 AM
To: [email protected]; Nagios Developers List
Subject: Re: [Nagios-devel] Event Profiler Patch
Hiren Patel wrote:
> Andreas Ericsson wrote:
>> Mathieu Gagn=E9 wrote:
>>> On 6/5/09 6:29 PM, Steven D. Morrey wrote:
>>>> p.s. Let me know how that patch goes on a 3x system I don't have a
>>>> running 3x to test it on, so all i can promise with that one is that i=
t compiles :)
>>> I'm trying it on a Nagios 3.0.6 system. Note that I had to remove all
>>> references to EVENT_CHECK_PROGRAM_UPDATE because it's an event only
>>> available in Nagios 3.1.x.
>>> All volatile data are already located on tmpfs partitions. So I'll have
>>> to try without tmpfs partitions afterward so I can compare impact on
>>> performances.
>> Steve, thanks for the patch. Mathieu, thanks for testing it out. If it's
>> useful to you, I'll apply it and make sure it's included in 3.1.1. The
>> data we might be able to gather from it may well be important for the
>> 3.2.0 release.
> what would be the impact of having this feature be a configuration
> setting in nagios.cfg, instead of having to compile with a flag to get
> the behavior? I'm wondering if it would be useful to be able to switch
> it on to get some information (perhaps during diagnosing something) and
> switch it off again if it's not wanted, without needing to recompile
> nagios for this?
One cmp+branch for each event executed. Almost certainly not too expensive.
Especially if gcc can be convinced that it *not* being set is the normal
case and optimize for it.
OP5 AB www.op5.se
on peace.
OpenSolaris 2009.06 is a cutting edge operating system for enterprises
looking to deploy the next generation of Solaris that includes the latest
innovations from Sun and the OpenSource community. Download a copy and
enjoy capabilities such as Networking, Storage and Virtualization.
Go to: http://p.sf.net/sfu/opensolaris-get
_______________________________________________
Nagios-devel mailing list
[email protected]
https://lists.sourceforge.net/lists/lis ... gios-devel
NOTICE: This email message is for the sole use of the intended recipient(s=
) and may contain confidential and privileged information. Any unauthorized=
review, use, disclosure or distribution is prohibited. If you are not the =
intended recipient, please contact the sender by reply email and destroy al=
l copies of the original message.
Original poster: ndreas Ericsson [[email protected]
