Re: [Nagios-devel] Ndo 1.4b7 patch : SSL connections
In compile it on my prod and I see theses errors:
*#include "../include/io.h" to remove in io.c (begining)
*-I/usr/include/openssl to add to all objects (maybe the common file
is not a good place to put the load of SSL.h).
I put the patch in production, I'll see the impact of SSL.
Jean
On Thu, Nov 6, 2008 at 2:36 PM, nap wrote:
> On Thu, Nov 6, 2008 at 2:24 PM, Hendrik B=E4cker wrote:
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> nap schrieb:
>>> Hi List,
>>> I wrote a patch for ndo 1.4b7 (ndomod and ndo2db) : the SSL
>>> connection. The code come from nrpe. I think this can be useful
>>> with distributed Nagios, the communications between the secondary
>>> nagios and ndo2db are in plaintext and we can see the name of the
>>> host in it.
>> Nice thing.
>>> The patch just apply the SSL connection to the sock of the
>>> connection between ndomod and ndo2db (just for a tcp connection, i
>>> don't think it is useful for unix socket...).
>> I guess it becomes very useful for the situation of "outside-my-lan"
>> nagios servers with "internal" db hosts.
> Even in the LAN, it's easy to make a man in the middle attack with
> ARP. And my security responsable do not want plaintext. Now He is
> happy and allow me to put distribuated nagios in production :)
>> But do you have ideas about the performance situation?
>> encryption takes cpu time and ndomod is usual not very quiet on wire.
>>> In the patch you can see the dh.h file from nrpe. In nrpe it's
>>> generated by ./configure but I don't know how to modified it. The
>>> Makefile need the ssl lib too, but I don't know how to modify the
>>> autoconf (I leave a Makefile.new in the patch to show what to
>>> modify), if someone can help me on this ;)
>> I will have a look at it.
> Thanks.
>>> For the moment the patch apply the SSL for all connections, but
>>> maybe we can put the use_ssl argument into ndo2db.conf and
>>> ndomod.conf.
>> That would be the best way.
> Ok, I'll see how to change it.
>>> I test with a small server and 4000 services and I don't see any
>>> overload of ndo2db or nagios due to the SSL. It can't be null, just
>>> small.
>> mkay... drop my above question ;)
> I test on my small dev server (virtual machine...), I'll put in onto
> my production server (6000 services) and see if the trafic of lo (ndo
> connexion in tcp localhost) is high or the load average reach the top
>> Nice thing, I am on your side for testing and helping hands.
> Thanks again :)
>> Hendrik
> Gab=E8s Jean
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.4.7 (MingW32)
>> iD8DBQFJEu/9lI0PwfxLQjkRAkUsAJ0T4PmN5cmtJjQ+SuDr6PEEXhzzswCZAQDx
>> h/Zbezr0h0P0ujl4yPJxZ1E=3D
>> =3D3D9L
>> -----END PGP SIGNATURE-----
>> This SF.Net email is sponsored by the Moblin Your Move Developer's chall=
enge
>> Build the coolest Linux based applications with Moblin SDK & win great p=
rizes
>> Grand prize is a trip for two to an Open Source event anywhere in the wo=
rld
>> http://moblin-contest.org/redirect.php? ... 00&url=3D/
>> _______________________________________________
>> Nagios-devel mailing list
>> [email protected]
>> https://lists.sourceforge.net/lists/lis ... gios-devel
