did you recognized the debug options in your ndo2db.cfg?
May be they will tell you more?
Hendrik
Am Freitag, den 18.01.2008, 20:18 +0100 schrieb Carlos Pereira:
> Hi Fulton, =09
>=20
> I have checked that and I can access the database : mysql -u nagios -p (n=
o problem). Also the event broker is enabled with -1 (broker everything).
>=20
> Thansks.
>=20
>=20
> - Carlos Pereira (alex12)
>=20
> This thread is located in the archive at this URL:
> http://www.nagiosexchange.org/nagios-de ... ttofaq_pi=
1[showUid]=3D8483
> =09
> > The first place I would look is to make sure that the username and pass=
word you
> > are using to connect to mysql are correct. Try connecting with the comm=
and
> > line client using them. If that works, check that your event brokering =
is
> > enabled (broker everything).
> >=20
> >=20
> > David Fulton
> > Systems Administrator
> > NuVox Communications
> > O:407-835-0470
> > C:321-246-2238
> > "Because Business is on the Line"
> >=20
> >=20
> >=20
> >=20
> > ________________________________
> >=20
> > From: [email protected]
> > [mailto:[email protected]] On Behalf Of Carlos
> > Pereira
> > Sent: Friday, January 18, 2008 1:24 PM
> > To: [email protected]
> > Subject: [Nagios-devel] Nagios 2.10 + ndoutils-1.4b7
> >=20
> >=20
> >=20
> > Hi folks, could someone help with nagios + ndoutil. I'm having a hard =
time to
> > sync nagios to dump its information throught ndo to a mysql database.
> >=20
> >=20
> >=20
> > The scenerio is as follow:
> >=20
> >=20
> >=20
> > Nagios installation is not a problem, I set up and it works fine with t=
he
> > default value. ( Nagios 2.10).
> >=20
> > Install everything , Mysql 5.0 and client , Apache2 & PHP5.
> >=20
> >=20
> >=20
> > Now when comes down to install ndoutils-1.4b7, problems start to popup=
> >=20
> > Obs: installing its not a problem but, writing to data sink it is ( THE
> > PROBLEM)
> >=20
> >=20
> >=20
> > 1 - Out put from ./configure ( Parts that have "no" while running comm=
and the
> > problems ( I think ) ) :
> >=20
> >=20
> >=20
> > checking for C compiler default output file name... a.out
> >=20
> > checking whether the C compiler works... yes
> >=20
> > checking whether we are cross compiling... no
> >=20
> > checking for suffix of executables...
> >=20
> > checking for suffix of object files... o
> >=20
> >=20
> >=20
> >=20
> >=20
> > checking limits.h presence... yes
> >=20
> > checking for limits.h... yes
> >=20
> > checking ltdl.h usability... no
> >=20
> > checking ltdl.h presence... no
> >=20
> > checking for ltdl.h... no
> >=20
> > checking math.h usability... yes
> >=20
> > checking math.h presence... yes
> >=20
> >=20
> >=20
> >=20
> >=20
> > checking signal.h presence... yes
> >=20
> > checking for signal.h... yes
> >=20
> > checking socket.h usability... no
> >=20
> > checking socket.h presence... no
> >=20
> > checking for socket.h... no
> >=20
> > checking stdarg.h usability... yes
> >=20
> > checking stdarg.h presence... yes
> >=20
> >=20
> >=20
> >=20
> >=20
> > checking for main in -lnsl... yes
> >=20
> > checking for socket in -lsocket... no
> >=20
> > checking for main in -lwrap... yes
> >=20
> > checking for strdup... yes
> >=20
> > checking for strstr... yes
> >=20
> >=20
> >=20
> > checking for compress in -lz... yes
> >=20
> > checking for mysql_store_result in -lmysqlclient... yes
> >=20
> > checking for mysql_connect in -lmysqlclient... no
> >=20
> > checking mysql/mysql.h usability... yes
> >=20
> > checking mysql/mysql.h presence... yes
> >=20
> > checking for mysql/mysql.h... yes
> >=20
> > MySQL library and include file(s) were found!
> >=20
> > checking for PQconnectdb in -lpq... no
> >=20
> >=20
> >=20
> >=20
> >=20
> >=20
> >=20
> > No problems while executing " MAKE"
> >=20
> >=20
> >=20
> > Followed as the README doc recommends inside the ndoutils-1.4b7.
> >=20
> > Copied all the files to the right places as well as the database, creat=
e users
> > grant permission and create th
...[email truncated]...
