Re: [Nagios-devel] feature request: passive check source address
------=_NextPart_000_0019_01C6C53F.6BD831E0
Content-Type: text/plain;
charset="us-ascii"
You could try with tcpserver (http://cr.yp.to/ucspi-tcp/tcpserver.html)
Instead of running NSCA directly you run can a script that use the
environment variables set by tcpserver to log to a file or syslog, then the
script exec to nsca.
Thomas
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf
> Of Thomas Sluyter
> Sent: August 21, 2006 5:26
> To: Nagios-Devel Nagios-Devel
> Subject: [Nagios-devel] feature request: passive check source address
> Hi all,
> I was wondering whether it would be possible to modify Nagios
> (or the
> NSCA daemon) in such a way that it logs the source address for an
> incoming service status update. Might seem a bit superfluous
> to most,
> but would you believe that in the environment we're working in right
> now most people don't even know -which systems- are submitting the
> passive checks? o_O
> Having this extra field in a log file somewhere would make
> troubleshooting much easier. It would also allow us to do some
> additional checking to safeguard ourselves against spoofing.
> Cheers!
> Thomas
> Using Tomcat but need to do more? Need to support web
> services, security?
> Get stuff done quickly with pre-integrated technology to make
> your job easier
> Download IBM WebSphere Application Server v.1.0.1 based on
> Apache Geronimo
> http://sel.as-us.falkag.net/sel?cmd=lnk ... bid=263057&
> dat=121642
> Nagios-devel mailing list
> [email protected]
Content-Type: application/x-pkcs7-signature;
name="smime.p7s"
filename="smime.p7s"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...[email truncated]...
