When you're not dumping STDERR to /dev/null does your script/binary
output anything useful? Try enabling some verbosity inside of it to see
where/why it's failing. It would be most useful to anyone else as well.
/eli
Billy Liang wrote:
> Hello,
> I am a newbie to the Nagios community. I developed an event handler for
> Nagios, but somehow it doesn't seem to be working. Here's the command
> definition for the event handler:
> define command {
> command_name fix_taosvcs
> command_line /opt/nagios/libexec/wpj/tao_event_handler
> $SERVICESTATE$ $SERVICESTATETYPE$ $SERVICEATTEMPT$ $SERVICEOUTPUT$
> 2>/dev/null
> If I ran the program separately such as the following, it works fine:
> /opt/nagios/libexec/wpj/tao_event_handle CRITICAL HARD 4 "CRITICAL Level
> 0 - 0 warning[] - 1 critical[PbxCmdMgr/0]"
> I tried running the program as nagios user, and it works. So I don't
> think it's permission problem. When I looked at the nagios log, it seems
> to have called the event handler. Following is the log:
> SERVICE ALERT: linux05;CHKTAO;CRITICAL;HARD;4;CRITICAL: Level 2 - 0
> warning[] 1 critical[PbxCmdMgr/0]
> [1134130290] SERVICE EVENT HANDLER:
> linux05;CHKTAO;CRITICAL;HARD;4;fix_taosvcs
> However when the program run under Nagios as event handler, it doesn't
> do anything. It's very perplexing. I am running Nagios 2.0b3, I am
> wondering if this version is too old for some of the macro that I used.
> In order for the event handler to do anything meaningful, it needs to
> have access to the content of $SERVICEOUTPUT$.
> Any advise on how to debug this problem will be greatly appreciated.
> Thank you.
> Billy
> This SF.net email is sponsored by: Splunk Inc. Do you grep through log
> files
> for problems? Stop! Download the new AJAX search engine that makes
> searching your log files as easy as surfing the web. DOWNLOAD SPLUNK!
> http://ads.osdn.com/?ad_id=7637&alloc_id=16865&op=click
> Nagios-devel mailing list
> [email protected]
