[PATCH] do not retain display_name and host alias
--------------010003050605070505090603
Content-Type: multipart/alternative;
boundary="------------030702040800040702070906"
--------------030702040800040702070906
Content-Transfer-Encoding: 8bit
Mies, Christian wrote:
> Hi Michael,
> thank you for the fast answer. After looking at documentation I set up
> retail_nonstatus_informatoin=0 in my Host Template.
> I've looked at the retension.dat, but there still standing the name before changing Alias Value.
afaik that setting does not affect the attributes being saved. there was
a patch in svn as proposed fix just in 3.2.2 - i've already removed that
in icinga 1.3.x because it's annoying and buggy.
http://nagios.svn.sourceforge.net/viewv ... ision=1447
> Do you know the changes between Nagios 3.2.1 and Nagios 3.2.3 in the retension Part? With nagios 3.2.1 everything working fine for moving files to the Database...
try the attached git diff as patch against 3.2.3 sources and verify the
updates from the original configs being imported/updated into the
database. there has been a discussion on various lists and forums about
that, but since that ran as "feature fix" into the core, there might be
a problem removing that in upstream of nagios.
kind regards,
michael
> Regards
> Christian
> i.A. Christian Mies
> Senior Consultant
> Tel: +49 (661) 103-874 (-333)
> Fax: +49 (661) 103-17874 (-334)
> mailto:[email protected]
> it-novum GmbH . Edelzeller Strasse 44 . 36043 Fulda . http://www.it-novum.com
> Handelsregister Amtsgericht Fulda, HRB 1934 . Geschäftsführer: Michael Kienle . Sitz der Gesellschaft: Fulda
> Der Inhalt dieser E-Mail ist vertraulich. Wenn Sie nicht der eigentliche Empfaenger sein sollten, informieren Sie bitte sofort den Absender oder vernichten umgehend diese Mail. Jegliche unerlaubte Vervielfaeltigung oder Weiterleitung dieser Mail ist strengstens verboten.
> This e-mail may contain confidential and/or priviledged information. If you are not the intended recepient (or have received this e-mail in error) please notify the sender immediately and destroy this e-mail. Any unauthorised copying, disclosure or distribution of material in this e-mail is strictly forbidden.
> ________________________________
> Von: Michael Friedrich [mailto:[email protected]]
> Gesendet: Do 14.04.2011 11:10
> An: [email protected]
> Betreff: Re: [Nagios-devel] WG: NDO 1.4b7 - nagios_hosts Field Aliases in Configtype 1
>> i.A. Christian Mies
>> Senior Consultant
>> Von: Mies, Christian
>> Gesendet: Do 14.04.2011 10:27
>> Betreff: NDO 1.4b7 - nagios_hosts Field Aliases in Configtype 1
>> Hi Nagios Devel List,
>> I hope I'm right at that list. I cannot find a seperate List for the NDOUtils
>> Historically we need to use NDO 1.4b7 - please don't ask why I'm using it.
>> Since the Nagios Update from 3.2.1 to 3
...[email truncated]...
