Description of my test:
1) I change MAX_PLUGIN_OUTPUT_LENGHT to 8192, recompile nagios
2) restart nagios
3) send very long string to external file
/usr/bin/printf "[%lu] PROCESS_SERVICE_CHECK_RESULT;martin-xp;Backup;0;$s=
tring"
$now > $commandfile
The nagios trimps my $string to 957 bytes. It seems, that nagios trimps s=
tring
to 1024 and 67 bytes is header.
I have only some minutes to go throuth sources and I found some buffer,s
that are defined directly for instance
common\snprintf line 1267
char buf1[1024];
char buf2[1024];
And there are many other constant defined to 1024
cgi\extinfo #define MAX_MESSAGE_BUFFER 1024
cgi\status.c MAX_MESSAGE_BUFFER 1024
include\comon.h #define MAX_INPUT_BUFFER 1024
When I blindly change some of then, I was able to send to nagios message
4033 bytes long.
Martin
Ethan Galstad napsal(a):
> [email protected] wrote:
>> Hello
>> I'm testing nagios 3.0b5. During my tests I try to change maximum plug=
in
>> output as written in documentation.
>> It's not working, it seems that some buffers are not defined based
>> MAX_PLUGIN_OUTPUT_LENGHT constant.
>> Martin
> Martin - Where are you seeing problems with the buffer length being
> clipped short of MAX_PLUGIN_OUTPUT_LENGTH? If that's happening, its a
> bug and needs to be fixed.
> Ethan Galstad,
> Nagios Developer
> Email: [email protected]
> Website: http://www.nagios.org
> This SF.net email is sponsored by: Splunk Inc.
> Still grepping through log files to find problems? Stop.
> Now Search log events and configuration files using AJAX and a browser.=
> Download your FREE copy of Splunk now >> http://get.splunk.com/
> Nagios-devel mailing list
> [email protected]
Martin
Superrychl=FD internet ADSL 512 od TISCALI ji=BE od 399 K=E8 m=ECs=ED=E8n=
=EC !
http://sluzby.tiscali.cz/domacnosti/ads ... php?r=3Dpb
